Ransomware on USB-stick?
http://forum.hddguru.com/viewtopic.php?f=10&t=41093
Page 1 of 2
Author:  bos [ March 18th, 2021, 7:35 ]
Post subject:  Ransomware on USB-stick?
Today a customer brought me a USB-stick for investigation. She said that when it was inserted, Windows could find it but asked the user if the stick should be formatted. She clicked "no" and pulled out, never touching it again. Then she called me and brought it here.
First thing I did was to mirror the stick, no read errors or anything like that. Got a 64GB image dump which I'm currently investigating in DMDE using Raw, NTFS and extFAT-filters. I expected to see something during the scan, but I get literally nothing except for a System Volume Information-folder and a single file called xyzhdndoakdahgjd1.txt, which is 20MB large. Even if she acidentally clicked "yes" to the format question, I would have seen a lot of old files, but no.
Sysinfo tells me the stick was formatted 2017-01-15 which is prior she bought it, and the mystery file is timestamped the day after. This does not add up, and something is fishy here but I cannot figure out what. I tried to recover the txt-file in DMDE but was told there was a I/O error so I cannot peek its contents.
What happened to the stick? Has it been the victim of a ransomware attack or something? I've never seen it before.
(While writing this post DMDE finished the scan 100% with 0% information found)
Author:  bos [ March 18th, 2021, 7:50 ]
Post subject:  Re: Ransomware on USB-stick?
I just performed a test by compressing the image (64GB):
bos@basterd:/backup/$ time gzip -1c Martina1.img > img.gz
real    6m45.718s
user    5m19.580s
sys     0m32.104s
bos@basterd:/backup/a$ du -sh img.gz
262M    img.gz
And that tells me that the image is basically filled with zeroes, so the drive has most likely been wiped. The test does not, however, give an answer to what the mystery txt-file is about; why it's there and what it contains.
Author:  Arch Stanton [ March 18th, 2021, 7:59 ]
When you look with disk editor, largely zeros? If she's really telling the whole story, my guess is corrupt translation table.
Ransomware leaves data behind for you to unlock after paying ransom. Ransomware that wipes everything does not make sense.
Heuh? After scanning your image file? If you open folder in hex editor and jump to first cluster file?
Author:  Arch Stanton [ March 18th, 2021, 8:05 ]
real    6m45.718s
user    5m19.580s
sys     0m32.104s
262M    img.gz
Or translation table corrupt. But then this file indeed would be a weird anomaly.
Author:  samstown [ March 18th, 2021, 8:57 ]
Question little bit out of topic...how do you deal with Ransomware device ? That USB drive could infect your system, isn't it ?
I got two disks from a customer, they are encrypted by ransomware. So far, I did nothing, I don't want to infect my system, I am building a Ubuntu PC for that purpose, is it the right way ?
Author:  Lardman [ March 18th, 2021, 9:13 ]
I've seen a few like that which had been intentionally wiped, not sure using what software though. Wonder what the contents of the file look like in hex. Id also be tempted to do a quick chip off to see some raw data, that would rule out the controller too.
If you're not mounting the device it should maintain separation, but it's always a concern with Windows and a device, less so with an image file. Linux is the easiest and cheapest way to sandbox it.
Author:  Arch Stanton [ March 18th, 2021, 9:13 ]
Drives are encrypted, they're not contagious if you just read them. Ransomware itself in essence is just an executable like for example Notepad.exe. If you attach a drive containing Notepad.exe nothing will happen unless Notepad.exe is is run. So the ransomware software needs to be executed to be dangerous. If an USB flash drive is prepped to spread ransomware, so setup to autorun the ransomware executable, then that would be a different story.
That being said, it is never a bad idea to run Linux with drives attached to image them better be safe than sorry.
Any idea already what ransomware you're dealing with?
Author:  samstown [ March 18th, 2021, 9:46 ]
Thank you. I don't want to hack this post. I'll create a new one with my ransomware question. Here is what customer got. He didn't pay. We had backup from last week. He's just looking for two files if possible.
Author:  Arch Stanton [ March 18th, 2021, 10:03 ]
Paying often enough is not a guarantee you'll be sent a decryptor. I have seen plenty of cases where people pay and get nothing, or a reply stating they want more.
To exactly know the ransomware upload an encrypted file here: https://id-ransomware.malwarehunterteam.com/ but it looks like Crysis Ransomware (= Dharma Ransomware). ID-Ransomware site will also tell you if there's a decryptor available.
If not:
- I regularly saw ransomware fail encrypt deeper nested folders, so you can always check those. Sometimes simply renaming them (get rid of ransomware extension) is enough to do the trick. A RAW scan will of course detect such files too which may be responsible for part of successful recoveries attributed to PhotoRec I sometimes see in forums.
- In general many ransomwares write encrypted data to newly created file and deletes original. If you're lucky original data may survive although there's of course the huge risk those newly created encrypted files overwrite 'vacant' clusters of the deleted original files.
Author:  samstown [ March 18th, 2021, 10:28 ]
If not:
Thank you for all the information, very usefull.
Author:  bos [ March 21st, 2021, 4:21 ]
Correct, I see only zeros when hex-dumping the file in DMDE.
This is the weird thing. I can hex-dump the file in DMDE, and I had no read errors whatsoever when I created the image. Yet DMDE tells me partition table is corrupt (but still lists a valid partition) and that there's an I/O when extracting the file itself.
Corrupt translation tables is a great guess of yours, and the best one I have for now. I will ask dust off the VNR and see if it can do some magic here.
Author:  Arch Stanton [ March 21st, 2021, 7:50 ]
Yes, so I meant do not use DMDE's browse feature to get to the file. Instead you can view the directory in editor which for example allows you to evaluate start cluster for the mystery file. If you have an invalid value there and cluster happens to be outside of the volume it may explain the IO error as it would be trying to read non existing LBA.
Partition table corrupt and DMDE detecting a valid partition is not uncommon, even without full scan it often detects 'lost' partitions.
Even just amount of data in dump may give a hint.
Author:  bos [ March 23rd, 2021, 5:56 ]
Now I made a dump of the chip. Single 64GB chip (ID 98DE949376, Toshiba P0170007-5) with unknown controller (potted IC). The only entropy I can find is near the beginning, looks like an XOR-key, but the rest of the chip is basically gray and white areas. Seems to me it's completely wiped.
I can't figure out what on earth happened. Wipe-out due to ESD or something?
Author:  bos [ March 23rd, 2021, 6:02 ]
I found this near the middle. Looks like ECC, and that's the only non-repetitive pattern I can find in the whole chip. Maybe this is the mystery file.
Other than that, I find no resemblances of LBN at all on the chip.
Author:  Arch Stanton [ March 23rd, 2021, 7:16 ]
https://youtu.be/hAAlDoAtV7Y
Author:  drun [ April 11th, 2021, 5:08 ]
You're right about this, but I just want to mention that some USB drives can infect systems without containing a visible executable (file attributes aside). Have a look at this. While it's unlikely to be relevant to this case, it's something to keep in mind while plugging in foreign USB drives into your computer.
Author:  Arch Stanton [ April 11th, 2021, 8:15 ]
Well, since this appears to be a mystery USB, and background story is also kind of vague, perhaps! Why not? Maybe someone was trying to hack/attack the client that brought in the stick.
https://www.bleepingcomputer.com/news/s ... b-attacks/
However I responded to samstown's message. And an USB drive or whatever drive containing ransomware encrypted data in itself is harmless. The encrypted data itself is harmless.
Author:  Spotmen [ May 6th, 2021, 17:32 ]
I am back.. with another Ransomware on QNAP RAID1 two disks (maybe would be nice to have a Ransomware Topic on this Forum?). I haven't received the drive from previous customer, he said it's not urgent as he only want two files.
This one is different, it's a private QNAP with all family pics. They are asking for 0.01 BTC (600 USD). Ransomware is QLocker.
I tried
https://id-ransomware.malwarehunterteam.com/ no solutions
When I try on
https://www.nomoreransom.org/crypto-sheriff.php?lang=en
I upload the file... and...back the to the main page where it's asking to choose a language. Looks like there is a bug. I treid with Chrome and FF.
Renaming/removing .7z file name to original extension doesn't work (that would have been too easy, of course).
Any hints ?
Author:  Arch Stanton [ May 6th, 2021, 19:32 ]
For laughs try unzipping them. I know of one case where it actually worked.
Author:  Spotmen [ May 7th, 2021, 1:55 ]
Thank you Arch , I did try Unzip, no luck.
The great URL you shared is helpfull.
https://www.bleepingcomputer.com/forums ... -nas-hack/
I think I'll try to recreate the RAID on UFS or PC3K and try a RAW scan.
Page 1 of 2 All times are UTC - 5 hours [ DST ]
