| Toshiba THNSNS240GBSP - not detected by the BIOS or system http://forum.hddguru.com/viewtopic.php?f=10&t=41114 |
Page 1 of 1 |
| Author: | bpjl [ March 22nd, 2021, 16:26 ] |
| Post subject: | Re: Toshiba THNSNS240GBSP - not detected by the BIOS or syst |
Searching for information on google, I came across my old topic on one of the local hardware repair forums. I completely forgot about that case and it concerned exactly the same disk model and the same problem. Then I received the following information: Quote: With Sandforce there is usually a problem with the controller software. Unfortunately, this controller encrypts data in hardware and it is not possible to read data from memory modules. A small percentage of the cases of these controllers can be recovered, but it depends on whether the software is still working minimally. I suspect that in this case I am dealing with the same problem. I decided to replace the disk with a new one and close the topic. As for the data - well, I will tell the owner that only tough guys do not make backups, but I would recommend that he start doing it |
| Author: | arvika [ March 22nd, 2021, 16:34 ] |
Toshiba rebranded this cotroller from Sandforce. Usually it is problem with controller. |
