 Post subject: Intel SSD 545S
PostPosted: April 20th, 2021, 5:30
is this SSD supported under PC3000
I was able to read half of data from different parts of drive.
From start and from the end of the drive(15GB from each side), data are not readable, from rest, there are some good readed parts and some not readed parts.
In the past I have some good recovery results with this drives, with same problems, but this one is little more problematic.
 Post subject: Re: Intel SSD 545S
PostPosted: April 20th, 2021, 6:32
Read how? Can you try with DeepSpar USB Stabilizer?
PostPosted: April 20th, 2021, 7:32
hello Arch Stanton
i don't have it, but I will tray with other tools.
PostPosted: April 20th, 2021, 8:06
I am specifically mentioning USB Stabilizer because I see people reporting 'unstable' SSDs handle lots better when connected via the Stabilizer. Even with drives with no LBA access at all in PC3000 etc. (busy).
Seems to me with SSDs, USB Stabilizer becomes must have tool.
