| I think my Hard Drive is dying, and my parents aren't keen o http://forum.hddguru.com/viewtopic.php?f=10&t=41280 |
Page 1 of 1 |
| Author: | Kevin254 [ May 7th, 2021, 15:38 ] |
| Post subject: | I think my Hard Drive is dying, and my parents aren't keen o |
Ok so. My PC is pretty old, being from 2015 I think. It's the only thing I have, and not only I, but my family also often uses it to access their e-mails and whatnot, I use it for light gaming (It won't handle better) and school, and I don't have a SSD, only 2 mechanical drives: 1TB drive with my system and most games on it, 500GB drive with random files and few games on it. Now, my system Disk is most probably failing, or starting to die after 5 years. I've had one or two times where it was randomly not detected at all, and if it is, then it barely loads Win10. While using the system, it is very, very often that my programs simply don't want to load, even Google. I can't even use CTRL+ALT+DEL because I have to wait a few minutes for my PC to recognize this action during these stutters. Usually rebooting helps, but with a mechanical drive and Win10... yeah. I've run CrystalDiskInfo and found problems, but when I tried to fix them, nothing helped. I need some help with either fixing this Disk, or convincing my parents to finally buy me a SATA SSD. Thanks in advance! |
| Author: | Lardman [ May 8th, 2021, 2:53 ] |
| Post subject: | Re: I think my Hard Drive is dying, and my parents aren't ke |
Kevin254 wrote: I need some help with either fixing this Disk, or convincing my parents to finally buy me a SATA SSD. 1. You can't fix mechanical problems only hide them - the drive is failing replace it before it dies and everything on it is lost. 2. Seriously - you want help convincing your parents ? What do you think we can do????!!! Hard drive are cheap - data recovery is not. |
| Author: | fzabkar [ May 8th, 2021, 17:32 ] |
People are reporting a hike in storage prices and are blaming it on crypto mining. |
| Author: | Lardman [ May 9th, 2021, 5:45 ] |
I wouldn't call it a hike - they're off the bottom, but there's no where near the same impact as graphics cards. On a domestic level single purchase 1TB SSD a 3-5% increase is the same as a pint over here. I wouldn't like to guess if it's crypto, chip shortage or good old fashion price inflation causing it. |
