HP 64GB flash drive with the FirstChip Controller.
http://forum.hddguru.com/viewtopic.php?f=10&t=41394
Author:  hack3rcon [ June 13th, 2021, 8:02 ]
Post subject:  HP 64GB flash drive with the FirstChip Controller.
I have an HP 64GB flash drive with below details:
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 100mA
USB Device ID: VID = FFFF PID = 1201
Device Revision: 0000
Manufacturer: NAND
Product Model: USB2DISK
Product Revision: 0.00
Controller Vendor: FirstChip
Controller Part-Number: FC1179
Flash ID code:      AD3A14030850 - Hynix - 1CE/Single Channel [MLC] -> Total Capacity = 16GB
Tools on web:       http://dl.mydigit.net/search/?type=all&q=FC1179
I visited https://www.usbdev.ru/files/firstchip/fc1179mptools/ and tested some of the MpTools programs, but they couldn't fix my drive!
Any idea to fix my flash drive?
Thank you.
Author:  Arch Stanton [ June 13th, 2021, 10:30 ]
Post subject:  Re: HP 64GB flash drive with the FirstChip Controller.
could not fix, did not work, got an error are all useless problem descriptions.
Author:  jeremyb [ June 13th, 2021, 17:48 ]
I think this is your first problem, 64GB UFD with 16GB of NAND.. Likely fake.
Author:  hack3rcon [ June 16th, 2021, 1:42 ]
I tested some tools and attached some photos:
Author:  hack3rcon [ June 16th, 2021, 1:45 ]
You right. How can I fix it?
Author:  Arch Stanton [ June 16th, 2021, 4:31 ]
Add 48 GB worth NAND?
Author:  hack3rcon [ June 19th, 2021, 8:31 ]
Thanks.
I just want to format it.
Author:  Arch Stanton [ June 19th, 2021, 10:53 ]
Have you considered it may be too kaput? And that even when you 'fix' it, it may be as good as useless?
Author:  HaQue [ June 22nd, 2021, 1:37 ]
crush that drive, and as you bring the hammer down, you must say "TAKE THAT YOU FAKE PIECE OF CRAP!"
