 Post subject: Microsoft Surface 1911 - m.2 - SK Hynix Cepheus
PostPosted: June 23rd, 2021, 8:08
Has anyone work on those Surface m.2 before ? I am looking for test point/safe mode. I've checked all resistor and coil, nothing bad. There's on short but I beleive it's fuse.
Spot
 Post subject: Re: Microsoft Surface 1911 - m.2 - SK Hynix Cepheus
PostPosted: June 23rd, 2021, 18:58
You may be able to provoke safe mode by disabling the 2.5V supply. You could do this by grounding the Enable pin, assuming it is connected to a pullup resistor.
https://www.ti.com/lit/ds/symlink/tlv62085.pdf
PostPosted: June 24th, 2021, 4:37
Thank you. I've tried to GND before the pull up, no luck.
PostPosted: July 1st, 2021, 9:44
ok, I desoldered the chip and could read it.
PostPosted: July 2nd, 2021, 17:52
Does it have any encryption when reading the chip directly?
I received one the other day and the customer was paranoid about us making any kind of physical modifications. So, we gave it back to him.
PostPosted: July 6th, 2021, 5:58
It is a PCI-E drive, but you are trying to read it over SATA.
PostPosted: July 6th, 2021, 15:56
Doh, you're right. It should have been obvious from the photo, but here is added confirmation:
https://www.techpowerup.com/review/sk-hynix-gold-p31-1-tb/
The controller is an in-house design by Hynix called "ACNT038," or "Cepheus."
Interface: PCIe Gen 3 x4, NVMe 1.3
PostPosted: July 10th, 2021, 7:16
No, you see NTFS with Bitlocker.
PostPosted: July 10th, 2021, 7:50
Thanks for the response.
PostPosted: August 17th, 2021, 8:05
How do you mean? Desoldered onto another adaptor, or do you have a test socket?
PostPosted: August 18th, 2021, 2:19
I got one of those.
https://www.dolphindatalab.com/product/ ... ter-smart/
PostPosted: August 18th, 2021, 14:21
suricate.ch wrote:
Thank you for the info! I have been searching for a test socket for these BGA 1620 chips.
Up until now I have been using a Samsung PM971 PCIe card, I removed the existing chip and replace with the one that requires recovery. Very fiddly reball job (using universal stencil) but I have had a lot of success using soldering/reball method (Device can be access via PC3000 portable PCIe adaptor)
This USB adaptor will save me quite a lot of time!
Again, thank you!
Users browsing this forum: No registered users and 24 guests
