Micro sd card pinout
Posted: August 26th, 2021, 14:37
Hi i have Verbatim 32 gb micro sd card and i need pinout for it. I will try to read nand directly thru linux and same communicate with standard pads. The idea is to see and read part of memory what some application is reading PGP public key and change this public cay to other. I tested that already with normal nand and is work now i need to transfer this trick to micro sd card but i dot have pinout.
