| Compact Flash Sandisk 16GB - UDMA http://forum.hddguru.com/viewtopic.php?f=10&t=41710 |
Page 1 of 1 |
| Author: | fzabkar [ September 18th, 2021, 4:09 ] |
| Post subject: | Re: Compact Flash Sandisk 16GB - UDMA |
Measure the voltage at the inductor above the "BBO" chip. https://www.ti.com/lit/ds/symlink/tps62040.pdf |
| Author: | Lardman [ September 18th, 2021, 8:44 ] |
Anything shorted what's the power consumption - anything getting hot? |
| Author: | suricate.ch [ September 20th, 2021, 8:53 ] | ||
| Post subject: | Re: Compact Flash Sandisk 16GB - UDMA | ||
Thank you guys. Getting 3V and 5 V
| Author: | suricate.ch [ September 21st, 2021, 9:54 ] |
Looks like only option will be chip off |
| Author: | jtb1982 [ September 22nd, 2021, 8:00 ] |
Hello suricate.ch, how are you? This CF seems a little old i believe tools like vnr or flash extractor have support for this controller. If you dont have tools to work with flash devices you can outsource, will be more easy than find a donor CF with the same controller. |
