HDD GURU FORUMS
http://forum.hddguru.com/
Safe mode in Kingston sm2280s3
http://forum.hddguru.com/viewtopic.php?f=10&t=41742
Page 1 of 1
Author:  mrdoktro [ September 29th, 2021, 9:05 ]
Post subject:  Safe mode in Kingston sm2280s3
Hello.
Does anyone know the location of the points in the Kingston sm2280s3 drive to put the drive in safe mode.
Thank you in advance
Author:  grevan [ September 29th, 2021, 11:18 ]
Post subject:  Re: Safe mode in Kingston sm2280s3
Just a guess, but besides the Phison controller there's a row of small capacitors, the third slot is empty. Not sure.
Author:  Agrail [ September 30th, 2021, 7:52 ]
Safe mode:
Author:  grevan [ September 30th, 2021, 11:16 ]
Thank you.
Author:  fzabkar [ September 30th, 2021, 13:41 ]
Is that a Phison PS3108 controller?
Author:  mrdoktro [ October 2nd, 2021, 7:44 ]
Yes this is ps3108, the solution given by @Agrail does not work. After the pads are short, the SSD turns off.
Author:  fzabkar [ October 2nd, 2021, 14:11 ]
Are you shorting the pads before powering on the SSD?
I would measure the voltages at all the potential shorting points. One of the pads must connect to a ball on the Phison controller, and one of the voltages must be at Vio levels. I would find the Vio supply by measuring the voltages at each of the inductors (the components with a white spot). You could also determine the Vcore and Vio voltages by measuring the tiny bypass capacitors surrounding the controller.
I have some ideas here, but your SSD may use a different approach.
How to locate "safe mode" shorting points on an SSD:
http://www.hddoracle.com/viewtopic.php?f=106&t=3088
Author:  mrdoktro [ October 4th, 2021, 7:29 ]
I approached the topic in a different way: I bought a working Goodram C50 disk based on the same chipset, I found a safe mode (3.3V to GPIO0), I desoldered the PS3108 chip, GPIO0 is an E1 ball. In my hard drive I located a vias between the sides of the laminate ... and ... @Agrail actually showed safe mode points ... :( and now another question: do I have a damaged controller or what?
Author:  fzabkar [ October 4th, 2021, 12:56 ]
What are the voltages at the inductors?
Author:  mrdoktro [ October 5th, 2021, 7:19 ]
@fzabkar 1.2V; 1.5V; 1.8V
Author:  fzabkar [ October 5th, 2021, 13:04 ]
If the resistances on each rail appear normal with the controller installed, the next place I would look at would be the crystal.
http://www.phpbb.com/
