Intel 320 BAD_CTX 130
http://forum.hddguru.com/viewtopic.php?f=10&t=41861
Author:  Kanzler [ November 4th, 2021, 13:47 ]
Post subject:  Intel 320 BAD_CTX 130
Hello again,
I'm a bit confused, recently recieved a Intel 320 with a BAD CTX bug
I'm using PC3K SSD for this:
I can read chip IDs and everything seems fine- tried rebuilding translator - no errors-
switched to Data Extractor - Tons of ECC Errors
I'm still pretty new to Data Recovery- any hints on what to do next?
Thanks a lot in advance
Author:  digisupport [ November 5th, 2021, 3:06 ]
Post subject:  Re: Intel 320 BAD_CTX 130
You can build translator but can“t remove bit errors in NAND, but make it possible to recover what can be rescued.
Bit errors ( NAND errors ) is the reason for BAD CTX.
ACE has a clip showing the how to use Intel Postville utility here https://blog.acelaboratory.com/pc-3000- ... amily.html
Author:  pepe [ November 5th, 2021, 7:07 ]
heating, cooling or modifying NAND VCC can help reducing bit errors in some cases...
Author:  digisupport [ November 5th, 2021, 8:04 ]
Agree pepe, in some cases temperature and voltage adjustments makes a big difference, but in the Intel 320 cases I have seen it didn't.
Author:  fzabkar [ November 5th, 2021, 14:22 ]
In-circuit recovery of SSDs with "weak" NAND:
http://www.hddoracle.com/viewtopic.php?f=106&t=2740
