[crucial][BX500] help recover
Posted: November 11th, 2021, 9:45
by tortorotto
Hello everyone.
I'm here because seems like you are the best in the field.
I have a faulty ssd crucial bc500 240gb wich shows this symtomps:
-Mount in windows but shows for 20/30 second part of filesystem and then get disconnected.
-Prevent 2 pc from post if used on a standard (not hot plug) sata port.
After shorted jp1
-Shows this ids in hardware and does not shows any disconnecting issue
SCSI\DiskSM2258AB-80-10000000____2014
SCSI\DiskSM2258AB
SCSI\SM2258AB-80-10000000____2
GenDisk
Already tried the trick of 30min of only sata connection for 2 time and it get better but still not able to access the data.
Can you show me a better path?
I'm a guy who know how to solder, low level programming, and basic of eletronics.
Recover the data is the point but i would love to learn something new, so give the chance to try something hacky :)
Re: [crucial][BX500] help recover
Posted: November 12th, 2021, 13:46
by fzabkar
I'm not a pro, but I would think that the SSD is affected by flaky NAND.
In-circuit recovery of SSDs with "weak" NAND:
http://www.hddoracle.com/viewtopic.php?f=106&t=2740
Posted: November 13th, 2021, 8:54
by tortorotto
Wow That's sounds cool. i'm gonna try. thanks
Posted: November 13th, 2021, 20:00
by Arch Stanton
Maybe I am missing something, but have you tried cloning it (HDDSuperClone + relay)?
