| Pinout for glued chip from USB http://forum.hddguru.com/viewtopic.php?f=10&t=42066 |
Page 1 of 1 |
| Author: | digisupport [ January 12th, 2022, 12:38 ] |
| Post subject: | Re: Pinout for glued chip from USB |
Never seen that "blop" here Michael |
| Author: | arvika [ January 12th, 2022, 13:09 ] |
I see it many times. Probably is same as before. You can measure signals from controller side. Do not touch the blob. |
| Author: | digisupport [ January 12th, 2022, 15:22 ] |
arvika, yes hooking up on controller side would be the way to go, but controller is also a blob. |
| Author: | arvika [ January 12th, 2022, 16:08 ] |
digisupport wrote: arvika, yes hooking up on controller side would be the way to go, but controller is also a blob. Hehehe. Life is brutal |
| Author: | fzabkar [ January 12th, 2022, 16:29 ] |
It should be relatively easy to locate the supply and ground pins (by looking for bypass capacitors, and testing for continuity with USB ground). That should then make it reasonably safe to experiment with the data and control pins. I would expect that the data pins would be grouped together. |
| Author: | HaQue [ January 16th, 2022, 21:19 ] |
does the PCB have any tsop48 pads on it as well? can you send photo of both sides of pcb? supply and ground on these are usually the middle on both sides. |
