| OCZ Vertex 4 256G not recognised http://forum.hddguru.com/viewtopic.php?f=10&t=42155 |
Page 1 of 1 |
| Author: | pepe [ February 15th, 2022, 5:55 ] |
| Post subject: | Re: OCZ Vertex 4 256G not recognised |
Hello, i don't think you have much chances against this thing without tools and knowledge. But there's a good chance to get it recovered in a lab. pepe |
| Author: | NikolayIslentev [ February 15th, 2022, 7:50 ] |
adresanet@gmx.com wrote: Can anybody give me an idea on how to deal with this drive? Hello. Connect terminal to J4. Maybe it will say something important about drive's condition. |
| Author: | adresanet@gmx.com [ February 15th, 2022, 12:20 ] |
NikolayIslentev wrote: adresanet@gmx.com wrote: Can anybody give me an idea on how to deal with this drive? Hello. Connect terminal to J4. Maybe it will say something important about drive's condition. Thank you for the response, but how do I do that, if it's not much to ask. I have some electronics knowledge but no programming. The closest thing that goes through my mind when I see 4 pins with +, Tx, Rx, GND comes to RS232 connection like it was on 2000's Nokia phones. But still, no idea about the kind of software or protocol used to comunicate with tis drives. |
| Author: | pepe [ February 15th, 2022, 20:55 ] |
An usb-serial port with the appropriate IO voltage, and yes, connect it to tx, rx and gnd, then open that COM port in a terminal sw. There you need to select the transfer rate, which is most probably 115200 baud, but it can be anything else as well. pepe |
| Author: | NikolayIslentev [ February 16th, 2022, 9:57 ] |
Old phone cables can work for that purpose. If you have one laying around, open it and check the chip inside. Many of those can be used as USB-to-Serial adapters. Alternatively, you can get CH341A for cheap. It can be used as both programmer and serial adapter. For terminal software, I use PUTTY. |
