 Post subject: partition wont delete
PostPosted: February 17th, 2022, 6:41
hello
i have SSD disk that i want to delete all his partitions
i had some trouble to do so , i tried "MiniTool partition wizard Technician" but operation wont be applied .
i tried with the diskpart but i come to dead road , can anyone help please .
 Post subject: Re: partition wont delete
PostPosted: February 18th, 2022, 2:51
Try the 'clean' command on diskpart.
DISKPART> select disk x
DISKPART> clean
then all partitions will be gone.
PostPosted: February 22nd, 2022, 13:21
than you very much for answer and your time
it try it , but nothing changed .
after clean i got this
and after insilizing i got that
all partitions as before with data on them
PostPosted: February 23rd, 2022, 3:55
Then there some sort of WP on the drive :shock:
PostPosted: February 23rd, 2022, 4:39
What's weird. Maybe Secure Erase then?
PostPosted: February 23rd, 2022, 5:45
the hole story that i have a small SSD disc 120 GO ,
and it become full , so i I bought a new one last week ,
i I cloned the old SSD in the new SSD , and i tried to extend the cloned partitions
the "SSD Secure Erase" function tells me that the disk is an active system and cant be erased
PostPosted: February 23rd, 2022, 6:15
The last image shows why there is a problem.
The Disk 1 device is reporting itself as 'SATAFIRM S11'
This is a controller/firmware issue and might be fixable but you would lose any data.
PostPosted: February 23rd, 2022, 6:23
I don't mind losing data at all , can you walk me please trough this process of fixing firmware issue
PostPosted: February 23rd, 2022, 6:33
https://forum.hddguru.com/viewtopic.php?t=38843
PostPosted: February 23rd, 2022, 7:01
thank you very much Lardman
by the way my disk is "PNY CS900 SSD" 240 GB .
i visited the topic , the guys talking about using "repair S11" tool
i download it , it seem that tools is specially for Phison chips only
PostPosted: February 23rd, 2022, 7:11
You're going to have to work with it a bit... https://forum.hddguru.com/viewtopic.php?f=10&t=39228 indicates connecting directly via sata rather than USB can also impact results.
PostPosted: February 23rd, 2022, 13:25
i try it with other pc and it give this error :
"ATA : ReadInfoBlock falied! Error: 0x51"
PostPosted: February 24th, 2022, 5:44
I tried to update the firmware but i didn't found the right version "SBFM61W5"
can anyone tell me where i can find it ?
PostPosted: February 24th, 2022, 10:15
since google give me zero results about the firmware "SBFM61W5"
i managed to get an other disk with the same brand and model
can anyone tell how can i extract firmware from it ??
Users browsing this forum: Agrail and 19 guests
