Micro SD - 6x4 Pattern [ Any Suggested Pinout ]
http://forum.hddguru.com/viewtopic.php?f=10&t=42369
Author:  Amarbir[CDR-Labs] [ May 4th, 2022, 3:25 ]
Post subject:  Micro SD - 6x4 Pattern [ Any Suggested Pinout ]
I have this Micro SD Card ,I have seen the resources of Two of my senior members and i cannot find any pattern like this in thier database ,Has anyone worked on this Micro SD Card ,Can you suggest something .
In VNR Database : The following 0042,0027,0029,0115,0174 are 6x4 Pattern
Here is the image
Author:  Amarbir[CDR-Labs] [ May 5th, 2022, 4:54 ]
Post subject:  Re: Micro SD - 6x4 Pattern [ Any Suggested Pinout ]
Hello Everyone ,
Pinout Is found ,Just Trying Out a Few permutations and combinations for NAND Reconstruction ,Hopefully We might be able to reconstruct the File System And get this data ,ECC and SA were XORED , Seems Like a Phison Controller
Author:  Amarbir[CDR-Labs] [ May 8th, 2022, 5:05 ]
Well,
This turned out to be a Phison With SLC and Normal Sections ,Both Sections had to be carved out and combined ,The end result was not a good file system but i managed to get the call recordings that the client wanted ,Lots of biterrors had a tough time
