 Post subject: anyone knows how to read this memory?
PostPosted: July 4th, 2022, 5:39
i got this flash with this memory hy27us08281a 64mb
how can i read it and recover photos?
thank u
 Post subject: Re: anyone knows how to read this memory?
PostPosted: July 5th, 2022, 4:25
you need some tool to read it, ie pc3k, VNR or FE, then reassemble the logical image from the dump and recover the files from that.
The reading part should be possible using some eprom programmer too, or using a microcontroller, if you have programming skills and are familiar with analyzing raw data in hex editor, but should be easier to find somebody with the right tools and have him/her to recover it for you.
PostPosted: July 6th, 2022, 2:26
thank you pepe for your reply what is the socket size for this? its not tsop48 its smaller
PostPosted: July 6th, 2022, 6:43
So it is the 12x17mm package? you can solder that to acelab wire adapter.
Found it in pc3k flash db so it can do it most probably.
PostPosted: July 7th, 2022, 12:11
thank you pepe
is there any socket adapter for this? anything i can read with progremer?
sorry to ask too much
Users browsing this forum: No registered users and 122 guests
