 Post subject: Is this NAND or EMMC?
PostPosted: July 7th, 2022, 6:04
I got a Hama USB drive in for recovery.
Inside looks like chinese, blob controller, this weird chip that i never seen in a usb and lots of hot glue.
Does anyone what this is? NAND or EMMC? Any clue about the pinout i can use to connect?
Please help. Thank you.
 Post subject: Re: Is this NAND or EMMC?
PostPosted: July 7th, 2022, 10:46
Online
It is NAND, BGA-154, quite rare. It could be 16-bit. Here it is refurbished chip, so can be more suprizes.
http://odzyskiwanie-danych.com.pl/image ... arvika.jpg
PostPosted: July 7th, 2022, 16:02
Adapter available - https://multi-recovery.com/subpages/MRBGA154.php
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
PostPosted: July 11th, 2022, 12:29
Bolo wrote:
With which adapter / converter can this MR BGA154 be connected to PC3000 flash and be able to read the chip, considering this is 16 bit.
I tried to contact you for details on Skype: Multi-COM found on your webpage but no answer, maybe skype not used.
PostPosted: July 11th, 2022, 12:42
Maybe you can fill in the dots ...
Thank you.
