| SM223TF controller http://forum.hddguru.com/viewtopic.php?f=10&t=42604 |
Page 1 of 1 |
| Author: | DRUG [ July 24th, 2022, 15:47 ] |
| Post subject: | SM223TF controller |
Hi guys, I'm having a tough time with this controller... I know that some other controllers like SM2234H have some tricks to detect block order, but how about this one? Can anyone share a tip? |
| Author: | arvika [ July 24th, 2022, 16:02 ] |
| Post subject: | Re: SM223TF controller |
Usually this controller use Join by page 0x200 as first step. Find some know file header, and analyze the sectors order at different dump. You will find order. |
| Author: | DRUG [ July 24th, 2022, 20:03 ] |
I just wonder that no matter what I do i get like 1-3 jpegs with 33 checked sectors, and all others with 4 checked sectors. I have a page size of 2112 with 512DA+6SA+10ECC and I think everything is set up ok, I'm also applying the Join by Pages (1Sector) and that's it... Perhaps a split by block is missing... Interleave Elimination did not help as well |
| Author: | Amarbir[CDR-Labs] [ July 25th, 2022, 5:44 ] |
DRUG wrote: I just wonder that no matter what I do i get like 1-3 jpegs with 33 checked sectors, and all others with 4 checked sectors. I have a page size of 2112 with 512DA+6SA+10ECC and I think everything is set up ok, I'm also applying the Join by Pages (1Sector) and that's it... Perhaps a split by block is missing... Interleave Elimination did not help as well Hi, Which tool are you using for this brother PC3K ? |
| Author: | DRUG [ July 25th, 2022, 6:38 ] |
Amarbir[CDR-Labs] wrote: DRUG wrote: I just wonder that no matter what I do i get like 1-3 jpegs with 33 checked sectors, and all others with 4 checked sectors. I have a page size of 2112 with 512DA+6SA+10ECC and I think everything is set up ok, I'm also applying the Join by Pages (1Sector) and that's it... Perhaps a split by block is missing... Interleave Elimination did not help as well Hi, Which tool are you using for this brother PC3K ? I'm using pc3k flash. |
