| eMMC stuck in 4k sector mode http://forum.hddguru.com/viewtopic.php?f=10&t=42605 |
Page 1 of 1 |
| Author: | dangowrt [ July 24th, 2022, 19:30 ] |
| Post subject: | eMMC stuck in 4k sector mode |
I wanted to try if using 4k sectore size instead of 512B emulated sectors makes any difference in terms of performance on my 008GB0 eMMC disk, so I set USE_NATIVE_SECTOR in EXT_CSD to 1. The performance difference turned out to be negligible, but 4k sectors are problematic e.g. because they are not supported by U-Boot loader. Hence I would like to return to use emulated 512B sectors (the factory state of the disk). However, writing 0 to USE_NATIVE_SECTOR[62] register has no effect. As newer versions of the eMMC specification are not (yet) public, I'd like to know if this register happens to be write-once -- if so, we should document that in mmc-utils to prevent other people doing stupid mistakes like me now... Anyone? |
| Author: | DRUG [ July 26th, 2022, 19:29 ] |
| Post subject: | Re: eMMC stuck in 4k sector mode |
Hi! How are you interfacing to read and write from this device? AFAIK this is a BGA 153 right? |
| Author: | dangowrt [ July 28th, 2022, 11:48 ] |
Yes, this is a BGA chip and it's soldered onto a devboard (Bananapi R3) I've been given access to. I can play with the eMMC because the board can also boot from SPI-NAND or SPI-NOR, hence not exclusively relying on eMMC for booting. I don't fancy removing it from the board, but if that's the only way to reset that setting, well, I'll go to a nearby phone repair shop and have them do that. |
