| GIGABYTE SSD 1TB PS3111 CONTROLLER http://forum.hddguru.com/viewtopic.php?f=10&t=42663 |
Page 1 of 1 |
| Author: | speakerbox [ August 24th, 2022, 5:05 ] |
| Post subject: | GIGABYTE SSD 1TB PS3111 CONTROLLER |
Hello, I have this drive that showed 20MB Soldered a jumper wire for safe mode. Uploaded recommended loader and created translator. I have access to data. I need a very big file (aprox 90GB) and opened a DE task to try to copy the list of ranges. However I get slow reading in most parts (120KBps) and 1.5MBps when it goes fast. I get bunches of 32 black blocks from time to time ("page marker checking error" (invalid data)). This is what slows a lot the process. Could this be the loader used? Also have bad MFT entries in the NTFS partition I noticed when trying to save the file that it would only copy 1GB stating wrong size Could memory chips be degraded so fast? Drive is from Jan 2021
| Author: | northwind [ August 25th, 2022, 4:28 ] |
| Post subject: | Re: GIGABYTE SSD 1TB PS3111 CONTROLLER |
speakerbox wrote: Could memory chips be degraded so fast? Drive is from Jan 2021 That's one and a half year. I'd say it exceeded the usual life span OK, exaggerating, but we've seen chips degrade in a blink of an eye, so... I think the translator you've built is probably fine. It's the chips that are in bad condition. Try heating/freezing, if you're VERY lucky, it might help you. However, I have to say that getting 90GB intact from a drive in this condition... I'd say chances are close to zero. |
| Author: | arvika [ August 25th, 2022, 5:18 ] |
Degradation of chips. Try reread many times. |
| Author: | speakerbox [ August 25th, 2022, 5:40 ] |
northwind wrote: speakerbox wrote: Could memory chips be degraded so fast? Drive is from Jan 2021 That's one and a half year. I'd say it exceeded the usual life span OK, exaggerating, but we've seen chips degrade in a blink of an eye, so... I think the translator you've built is probably fine. It's the chips that are in bad condition. Try heating/freezing, if you're VERY lucky, it might help you. However, I have to say that getting 90GB intact from a drive in this condition... I'd say chances are close to zero. arvika wrote: Degradation of chips. Try reread many times. Thank you both for your input!! I will let you know the outcome |
| Author: | speakerbox [ August 25th, 2022, 10:56 ] |
Well, situation didnt change either using freeze spray or heating the chips up to 160 degrees celsius As this is a *.vsddsqlzip file, we can assume it is deeply f*cked |
| Author: | fzabkar [ August 25th, 2022, 13:27 ] |
One more thing you could try would be to adjust the NAND Vcc supply in-circuit. Run it through the range from 2.7V to 3.6V. |
| Author: | speakerbox [ August 25th, 2022, 19:07 ] |
fzabkar wrote: One more thing you could try would be to adjust the NAND Vcc supply in-circuit. Run it through the range from 2.7V to 3.6V. where is this feature? I cannot find it |
| Author: | fzabkar [ August 25th, 2022, 19:33 ] |
speakerbox wrote: fzabkar wrote: One more thing you could try would be to adjust the NAND Vcc supply in-circuit. Run it through the range from 2.7V to 3.6V. where is this feature? I cannot find it That's because it was a suggestion I put forward at the HDD Oracle. The idea is that you intercept the PCB's 3.3V supply and inject your own variable supply. |
| Author: | speakerbox [ August 30th, 2022, 14:56 ] |
fzabkar wrote: speakerbox wrote: fzabkar wrote: One more thing you could try would be to adjust the NAND Vcc supply in-circuit. Run it through the range from 2.7V to 3.6V. where is this feature? I cannot find it That's because it was a suggestion I put forward at the HDD Oracle. The idea is that you intercept the PCB's 3.3V supply and inject your own variable supply. I assume I would have to cut the trace for that and then inject V |
| Author: | speakerbox [ August 30th, 2022, 15:00 ] |
Update so far: I retrieved the 97GB file but has 0.24% corrupted data, so this one sucked. As it was a compressed file database it couldnt be loaded. Tried with freeze spray, heating etc... no luck. Garbage chips. Anyway there where a few negligences here... - Server did not have the UPS turned on, and the lights went off - Corrupted firmware in SSD - They make the BACKUP of the system from that SSD to THAT SELF SSD in another folder. How stupid is that? - They make 100GB backups every few days and the memory chips where degraded. Only a year and a half from new. |
| Author: | fzabkar [ August 30th, 2022, 15:13 ] |
speakerbox wrote: fzabkar wrote: speakerbox wrote: fzabkar wrote: One more thing you could try would be to adjust the NAND Vcc supply in-circuit. Run it through the range from 2.7V to 3.6V. where is this feature? I cannot find it That's because it was a suggestion I put forward at the HDD Oracle. The idea is that you intercept the PCB's 3.3V supply and inject your own variable supply. I assume I would have to cut the trace for that and then inject V Remove the inductor and inject the voltage into the load side of the inductor. |
| Author: | fzabkar [ August 30th, 2022, 17:14 ] |
Would it be possible to upload a resource dump for this SSD? It would be interesting to see what the defect lists and SMART look like. |
