AS2258-BN
http://forum.hddguru.com/viewtopic.php?f=10&t=42677
Author:  sempre [ August 31st, 2022, 15:01 ]
Post subject:  AS2258-BN
Hi to all! :mrgreen:
Model Name: AXIS 400 STT120L-4MAAZG2 DC2106
Controller Name: AS2258-BN
Total Capacity: 120GB
AS2258 - is a modified PS3111
But AS2258 is pretty rare.
Do you know of any PC3000 compatible loader for this case. I've tried some, but no success!
Author:  fzabkar [ August 31st, 2022, 18:42 ]
Post subject:  Re: AS2258-BN
I have examined the firmware payloads (.bin ) within some MPtool archives:
https://xfjportal.com/index.php/2020/12/14/asolid-as2258-mptoolmask-phision-ps3111/
After decoding these BINs, I see that they consist of several similar modules, each with a size of around 1.4MB (0x169230). Could these be loaders ???
Offset(h) 00       04       08       0C
          name              size     offset
00001DF0  32332E34 5F415332 00169230 00001F80  23.4_AS2..’0...€
00001E00  32333131 5F415332 00169230 0016B1B0  2311_AS2..’0..±°
00001E10  32333132 5F415332 00169230 002D43E0  2312_AS2..’0.-Cà
00001E20  32333135 5F415332 00169230 0043D610  2315_AS2..’0.CÖ.
00001E30  32333136 5F415332 00169230 005A6840  2316_AS2..’0.Zh@
00001E40  37332E34 5F415337 00169230 0070FA70  73.4_AS7..’0.púp
00001E50  37333131 5F415337 00169230 00878CA0  7311_AS7..’0.‡Œ
00001E60  37333132 5F415337 00169230 009E1ED0  7312_AS7..’0.ž.Ð
00001E70  37333135 5F415337 00169230 00B4B100  7315_AS7..’0.´±.
00001E80  37333136 5F415337 00169230 00CB4330  7316_AS7..’0.ËC0
00001E90  41332E32 5F415341 00169230 00E1D560  A3.2_ASA..’0.áÕ`
00001EA0  41333131 5F415341 00169230 00F86790  A311_ASA..’0.øg.
00001EB0  41333135 5F415341 00169230 010EF9C0  A315_ASA..’0..ùÀ
00001EC0  41333136 5F415341 00169230 01258BF0  A316_ASA..’0.%‹ð
00001ED0  42332E34 5F415342 00169230 013C1E20  B3.4_ASB..’0.<.
00001EE0  42333131 5F415342 00169230 0152B050  B311_ASB..’0.R°P
00001EF0  42333132 5F415342 00169230 01694280  B312_ASB..’0.iB€
00001F00  42333135 5F415342 00169230 017FD4B0  B315_ASB..’0..Ô°
00001F10  42333136 5F415342 00169230 019666E0  B316_ASB..’0.–fà
00001F20  43332E32 5F415343 00169230 01ACF910  C3.2_ASC..’0.¬ù.
00001F30  43333131 5F415343 00169230 01C38B40  C311_ASC..’0.Ë@
00001F40  43333135 5F415343 00169230 01DA1D70  C315_ASC..’0.Ú.p
00001F50  43333136 5F415343 00169230 01F0AFA0  C316_ASC..’0.ð¯
00001F60  44332E32 5F415344 00169230 020741D0  D3.2_ASD..’0..AÐ
00001F70  44333136 5F415344 00169230 021DD400  D316_ASD..’0..Ô.
I could extract them, if they would be of any use.
I notice that all the numbers are big-endian.
Author:  fzabkar [ September 1st, 2022, 19:36 ]
FWIW, here are the firmware modules I have extracted from an MPTool package:
http://users.on.net/~fzabkar/SSD/ASolid/AS2258_MPtool_FW_BINs.7z
These are the tools I wrote to work with the package files:
http://users.on.net/~fzabkar/FreeBasic_W32/ASolid/
I see a reference to PS3111 in one of the files.
Author:  sempre [ September 2nd, 2022, 7:54 ]
Hi!
unfortunately I no longer have this ssd the customer took it back.
Thanks!
Author:  Amarbir[CDR-Labs] [ September 4th, 2022, 7:04 ]
Well,
PS3111 and several others Acelab does not have enough loaders ,I have returned SSD's Back to clients several times
Author:  fzabkar [ September 4th, 2022, 15:41 ]
Are Ace's loaders their own original code, or are they Phison's factory loaders, or Phison loaders that have been hacked by Ace?
The ASolid MPTool contains two BIN files, one for MP and another for RDT. I'm guessing that the RDT BIN is used for burn-in (Rapid Diagnostic Test ?), while the MP BIN is the final shipped firmware (Mass Production ?).
Author:  jtb1982 [ September 14th, 2022, 13:56 ]
I receive the same ssd few days ago i must return back to the client but researching in the web i find this thread http://flash-extractor.com/forum/viewtopic.php?p=63248 from flash extractor apparently the drive does not use encryption
instead xor but for ecc code uses lpdc.
