HDD GURU FORUMS
http://forum.hddguru.com/
SSD blocked with blue screen and white message on windows 10
http://forum.hddguru.com/viewtopic.php?f=10&t=42732
Page 1 of 1
Author:  whatifwe [ September 19th, 2022, 13:50 ]
Post subject:  SSD blocked with blue screen and white message on windows 10
It's a kingston ssd and this is the message 'File di log F:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt' then it said 'Arrest the system' or 'Advanced options'. Between the various options of Advanced options' there was 'prompt commands' where I tried some stuff suggested online, but nothing worked.
At the moment is at a repair shop who so far told me there is nothing he can do.
Author:  Lardman [ September 19th, 2022, 14:53 ]
Post subject:  Re: SSD blocked with blue screen and white message on window
If the drive has failed the worst thing you can do is have a repair shop messing with it, do you know if it's a drive failure or a Windows problem? Which kingston is it?
There appears to at least be some logical access so it's not completely dead yet so the data should at least still be recoverable.
Author:  whatifwe [ September 19th, 2022, 14:56 ]
The shop says drive failure (rather than windows), but it doesn't necessarily mean that it's making it worse.
Author:  Lardman [ September 19th, 2022, 14:59 ]
Anything you do to a dying SSD is making it worse, there's a very small window in which you can recover data from them before they die completely and recovery becomes a nightmare.
http://www.phpbb.com/
