| MacbookPro A1990 http://forum.hddguru.com/viewtopic.php?f=10&t=42763 |
Page 1 of 1 |
| Author: | bos [ October 4th, 2022, 6:32 ] |
| Post subject: | MacbookPro A1990 |
We have got an inquiry for a NAND-recovery on this Macbook, but we have no experience for Apple's stuff so we are going to send the customer to another -- bigger -- DR-house. However, this doesn't stop me from learning something new Since it's Apple, my first thought is that their NAND-protocol is a proprietary one, and probably even encrypted. So not simply a chip-off recovery by pulling the NAND and dump it. Do they (Apple) use their own controllers, or do they use standard ones? For encrypted drives, is there even a single chance for recovery, or is it the nowadays standard "bad luck, you should have backed up your data"? |
| Author: | Lardman [ October 4th, 2022, 6:46 ] |
| Post subject: | Re: MacbookPro A1990 |
https://www.it-tech.com.au/recover-data ... -computers has the basics. Unless it's removeable or there's a lifeboat it's either a case of fix the board or your SOL. |
| Author: | Spotmen [ October 5th, 2022, 5:07 ] |
Try DFU and revive if possible, sometimes it looks dead but DFU works. https://mrmacintosh.com/restore-macos-f ... -dfu-mode/ If not, you need to fix the board and hope short didn't hit CPU or NAND. Best place to learn is - |
| Author: | trumanhw [ November 30th, 2022, 18:58 ] |
Fixing the board might be easier. You can then break even on the Data ... and sell the logic board to make money. ? |
