SSD SM2258XT, 240GB FW failure - Verico Nighthawk
http://forum.hddguru.com/viewtopic.php?f=10&t=42881
Author:  eiedr [ November 22nd, 2022, 15:17 ]
Post subject:  SSD SM2258XT, 240GB FW failure - Verico Nighthawk
Hello coleagues,
i do need support for a SSD Verico Nighthawk - controller SM2258XT, NAND not marked.
It looks like FW panic/failure, and I want to ask if someone can load the resources in order to get access to the user data.
The drive is identifying correctly in ROM Mode and shows 1Gb as capacity .
Weite me in private if more comfortable with this.
Otherwise, I will appreciate any support
Author:  eiedr [ November 23rd, 2022, 8:30 ]
Post subject:  Re: SSD SM2258XT, 240GB FW failure - Verico Nighthawk
I am going to add some pictues. It is probalby very rare model and PCB version.
Anyway, two aspects are not nice.
1. the NAND chips are not marked other then T8 T9 U4 and U5
2. I can see some possible sign of damage on the chip U5 ( from how it looks a very dark spot)
What do you guys think about this?
Author:  eiedr [ November 23rd, 2022, 12:37 ]
More details about the SSD drive, thanks to SMI flash ID tool.
Model: SM2258AB-80-10000000
Fw : 20141211
Size : 0 MB [0.0 GB]
Controller : SM2258AA in ROM Mode
Bank00: 0x45,0x3e,0x98,0xb3,0x76,0x72,0x0,0x0 - Sandisk 64L BiCS3 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank01: 0x45,0x3e,0x98,0xb3,0x76,0x72,0x0,0x0 - Sandisk 64L BiCS3 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank02: 0x45,0x3e,0x98,0xb3,0x76,0x72,0x0,0x0 - Sandisk 64L BiCS3 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank03: 0x45,0x3e,0x98,0xb3,0x76,0x72,0x0,0x0 - Sandisk 64L BiCS3 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank04: 0xf,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank05: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank06: 0x7f,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank07: 0xe,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank08: 0xf,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank09: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank10: 0x7f,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank11: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank12: 0xf,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank13: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank14: 0x7f,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank15: 0xe,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank16: 0xf,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank17: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank18: 0x7f,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank19: 0xe,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank20: 0xf,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank21: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank22: 0x7f,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank23: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank24: 0xf,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank25: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank26: 0x7f,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank27: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank28: 0xf,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank29: 0x6,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank30: 0x7f,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank31: 0xe,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Author:  eiedr [ November 24th, 2022, 5:22 ]
Does anybody know for sure if this controller SM2258XT is using data encryption?
Is chip off method then a solution or “just”fixing the firmware, generating translator makes sense.
Author:  arvika [ November 24th, 2022, 11:16 ]
SM2258XT use encryption.
Author:  northwind [ November 25th, 2022, 3:48 ]
Yes, you can't transfer chips to other board, it won't work.
Author:  eiedr [ November 26th, 2022, 9:55 ]
Thank you both for your valuable answers.
What would be as solution for this case? Who can help ( maybe remote) ?
Author:  northwind [ November 28th, 2022, 3:42 ]
Do you have PC-3000 SSD?
Author:  eiedr [ November 28th, 2022, 3:59 ]
Not yet, i do not have yet PC3000. That is why I cannot purchase the SSD module separately.
I’m sure will be the easiest and fastest solution. Still, not sure if. This model will be supported.
Would you like to have a try?
Author:  northwind [ November 28th, 2022, 7:24 ]
I can certainly try, but you'd have to send me the drive.
