WD Green SSD 480GB Short Pins board Location SM2258XT
http://forum.hddguru.com/viewtopic.php?f=10&t=42927
Page 1 of 2
Author:  skillet [ December 8th, 2022, 23:02 ]
Post subject:  WD Green SSD 480GB Short Pins board Location SM2258XT
WD Green SSD 480GB (SanDisk) Short Pins board Location SM2258XT 20-82-00469-2 54-50-02087-2
Can anyone please tell / show me where the short pins for safe mode are located on this board urgently.
Author:  lcoughey [ December 9th, 2022, 0:10 ]
Post subject:  Re: WD Green SSD 480GB Short Pins board Location SM2258XT
Perhaps a photo of each side would help.
Author:  arvika [ December 9th, 2022, 11:26 ]
Your drive have controller SM2258XT or 20-82-00469-2.
Author:  skillet [ December 9th, 2022, 20:56 ]
Author:  lcoughey [ December 9th, 2022, 21:11 ]
Chip off with FE. Not yet supported by PC3000.
Author:  fzabkar [ December 9th, 2022, 22:01 ]
Is there any activity via SATA?
I can see a 5V e-fuse (marking ACH) at U10 near the TI PMIC (V079). If necessary, the e-fuse can be bypassed by linking the R58 or R19 pads on the other side (confirm with measurements before trying this).
There should be 3 supply voltages at inductors L2, L4 and Lx.
Author:  fzabkar [ December 9th, 2022, 23:03 ]
U10 is actually a P-channel MOSFET configured as a high-side load switch. I expect it switches 5V power to the whole PCB under the control of the DevSleep pin. I have seen a similar component ("1D") fail on other Sandisk SSDs. This MOSFET can be bypassed by bridging R19 or R58.
NTLUS4195PZ, ON Semiconductor, Power MOSFET, -30V, -4.0 A, Single P−Channel, marking ACx, UDFN6:
https://www.onsemi.com/pdf/datasheet/ntlus4195pz-d.pdf
Author:  skillet [ December 11th, 2022, 19:46 ]
WD Green SSD 480GB (SanDisk) as per photo
We only need
Short Pins board Location for Safe Mode
Author:  matthew555 [ January 12th, 2023, 5:48 ]
As a complete newby, I've experienced the same issue with the same board, is there a way to fix by removing and soldering resistors/capacitors without using pc-3000, or software is the only way?
Is this small black chip shorted/burned (color is darkest than the other) ?
Help is really appreciated for moving first steps
Author:  matthew555 [ January 12th, 2023, 5:55 ]
Did you fixed the issue ? if yes, can you explain how you did ?
Have same issue with same exact board, the only problem is that I'm a newby, but need to save some data inside
Author:  fzabkar [ January 12th, 2023, 11:55 ]
@matthew555, if you want to test the hardware, measure the voltages between ground (eg a screw hole) and each of the inductors (L2, L4, L?). Also measure the voltages at R58 and R19.
Author:  matthew555 [ January 12th, 2023, 15:35 ]
Thanks very much for your support and help ...
this are the values :
L2 = 2.74VDC
L4 = 1.25VDC
L3 = 0.02VDC
R58 = 5VDC
R19 = 5VDC
Author:  matthew555 [ January 15th, 2023, 13:45 ]
I've checked with a thermal-camera and in this area it seems to be concentrated all the heat
Wrote a mail to PC-3000 and it seems there is no compatibility with my Sandisk-based CPU 82-00469 controller.
Is there a chance I can do for fix and save some files ? replacing L2 L3 and L4 could lead to a possible fix ?
Author:  fzabkar [ January 15th, 2023, 14:47 ]
@matthew555, it would appear that the output voltage at L3 is shorted to ground. There are several possible culprits, but let's hope that there is a shorted capacitor, in which case the fix would be to remove it.
I would measure the resistances of each of the capacitors so that we can narrow down the possibilities.
Author:  matthew555 [ January 16th, 2023, 6:26 ]
L1 = 0.4 Ωohn
L2 = 0.4 Ωohm
L3 = 0.4 Ωohm
all 3 sounds 'beeb' when touched with tester that means there is connectivity between the 2 poles - (Using MASTECH MS8910 Smart SMD Tester)
Author:  Lardman [ January 16th, 2023, 11:14 ]
@matthew555, have you just measured the resistance of the inductors themselves? The power line L3 is on appears to be shorted to ground, if you measure it's resistance to a screwhole it should confirm. It's then a question of finding out which item on the line is shorted to ground, the inductors are inline and have no connection to ground.
@fzabkar, I don't remember seeing one but have you put a guide together about the basics of ssd testing like the tvs diode faq? It might save some repetition in the long run.
Author:  fzabkar [ January 16th, 2023, 13:10 ]
@Lardman, I do have tutorials on switchmode power supplies, but now we're looking for a shorted capacitor, so they wouldn't be useful.
Author:  matthew555 [ January 16th, 2023, 15:39 ]
L2 = 54.0K-ohm (measurement came after few seconds)
L3 = start at 5.0M-ohm got fixed value around 0.74M-ohm (fixed measurement came after a countdown values of a couples of minutes long)
L4 = 2.38K-ohm (measurement came after few seconds)
Author:  fzabkar [ January 16th, 2023, 16:47 ]
It looks like there is no short, so that would suggest that the PMIC (V079) is faulty. Try applying downward pressure on the IC, just in case there is a solder problem with the BGA balls. If this doesn't work, then it may be possible to patch in an external supply, but we would need to know the voltage.
BTW, this IC is made by Texas Instruments, but it doesn't appear to be a standard off-the-shelf part.
Similar parts ...
LM10507, 3x Programmable Buck + 2.5V 250mA LDO Power Management IC (PMIC), marking V087, DSBGA (34):
http://www.ti.com/lit/ds/symlink/lm10507.pdf
LM10504TMX/NOPB, Texas Instruments, marking V039 - Triple Buck + LDO Power Management IC (PMIC)
http://www.ti.com/product/LM10504
http://www.ti.com/lit/ds/symlink/lm10504.pdf
LM10524TMX/NOPB, Texas Instruments, marking V088 - Triple Buck Power Management IC (PMIC) for SSDs
http://www.ti.com/product/LM10524
http://www.ti.com/lit/ds/symlink/lm10524.pdf
LM10524TMX-A/NOPB, Texas Instruments, marking V089 - Triple Buck Power Management IC (PMIC) for SSDs
Author:  fzabkar [ January 16th, 2023, 19:22 ]
This thread has a photo of the ball-out:
https://www.linux.org.ru/forum/general/16323481
Page 1 of 2 All times are UTC - 5 hours [ DST ]
