HDD GURU FORUMS
http://forum.hddguru.com/
Read a Flash IC BGA 152
http://forum.hddguru.com/viewtopic.php?f=10&t=42942
Page 1 of 1
Author:  corrado@exformat.com [ December 17th, 2022, 4:57 ]
Post subject:  Read a Flash IC BGA 152
Hello, I kindly ask for the dump of two flash BGA micron 152 (code 6zb27 nw582) I would send them already unsoldered, they are part of a 256GB cfast 2.0 signed tpx cfs6xt. Obviously I pay for the trouble, in an attempt to recover the data. The controller shows no signs of life. Let me know a cost privately and I'll ship them already unsoldered. Thank you. Ilive in Italy thank
Author:  fzabkar [ December 17th, 2022, 15:04 ]
Post subject:  Re: Read a Flash IC BGA 152
https://www.micron.com/support/tools-and-utilities/fbga?fbga=nw582
NW582 = MT29F1T08CUCBBH8-6R:B
Author:  eiedr [ December 17th, 2022, 17:24 ]
Hi there,
you can post them to me. i can help you with the dump.
Ioan
Author:  Amarbir[CDR-Labs] [ December 18th, 2022, 0:56 ]
Well,
Can you show the device Photo from were you took this out ,From my guess even if you read the NANDS no use they might be encrypted ,Also what controller does your Cfast Use Is It 5XXX Series then you might need NVME SSD Type support tool like PC3K Portable .
Author:  arvika [ December 18th, 2022, 3:11 ]
Start with photo. Do not desolder. If you overheat the chips recovery could be not possible.
Author:  corrado@exformat.com [ December 18th, 2022, 10:29 ]
Well,
is a cfast 2.0
cfs6xt
i hope it's not encrypted... the controller is SM2246xt
if you have a 3K pc and you do the work for me hoping it will be recoverable what are the costs? thank you
Author:  arvika [ December 18th, 2022, 10:38 ]
Still not paste photo. Most cases based on this controller is recoverable by FE. Sometimes there is issue with dump quality and case need some rereadings.
Author:  lcoughey [ December 18th, 2022, 12:04 ]
Pc3k works with that controller with the SSD intact. I'm not sure that pcek flash supports that controller.
If you want a successful recovery l, send the fully intact SSD.
http://www.phpbb.com/
