| Can Low Level Format Tool be used through a bootable USB? http://forum.hddguru.com/viewtopic.php?f=10&t=43133 |
Page 1 of 1 |
| Author: | francisco [ February 15th, 2023, 16:10 ] |
| Post subject: | Can Low Level Format Tool be used through a bootable USB? |
Hello everyone, I've been searching through the forum but I didn't find what I was looking for. Any help would be much appreciated. I've done a secure erase to my Kingston SSD with Parted Magic. I couldn't ran sanitize, seems to be not compatible. I also ran a non-destructive wipe also with Parted Magic but I didn't get the desired results, the problem is still there. I copied the executable LLFT to Parted Magic USB but, when trying to open it, the system doesn't recognice it. Any idea on how to do this? Thank you. |
| Author: | Arch Stanton [ February 15th, 2023, 16:12 ] |
| Post subject: | Re: Can Low Level Format Tool be used through a bootable USB |
Quote: the problem is still there what problem? what are you trying to accomplish? |
| Author: | francisco [ February 15th, 2023, 16:24 ] |
I have malware since many years ago but I'm not able to get rid of it. You can clearly see it when using the mouse wheel, does not respond correctly even with new mouses. You go down with the wheel and the webpage goes up and the next time down. It doesn't work. I even contacted years ago with antivirus staff but they didn't solve the problem. Edit: That's the first sign of the malware. With time the computer gets worse with other things. |
