Cricial MX500 (ct2000mx500ssd1)
http://forum.hddguru.com/viewtopic.php?f=10&t=43135
Author:  hdd_guru [ February 16th, 2023, 16:01 ]
Post subject:  Cricial MX500 (ct2000mx500ssd1)
Hello guys,
I wonder if anyone can shed some light on this, please. That would be greatly appreciated.
I have a shorted MX500 (the client connected the wrong PSU cable to the SSD and shorted it.
I checked for C674, C675, C676, C500 and C673 and found no issues. C500 was the only one on the board actually. C673, 4, 5, 6 were not on the board at all.
I wonder if you could please point me in the right direction.
Thank you so much in advance.
File comment: ct2000mx500ssd1
Author:  Lardman [ February 16th, 2023, 16:07 ]
Post subject:  Re: Cricial MX500 (ct2000mx500ssd1)
Check the zero ohm resistor for a start, then the efuses, then on to the voltage checks at the inductors. What's the current draw?
Author:  fzabkar [ February 16th, 2023, 16:27 ]
MP5016H, Monolithic Power, 2.7V - 22V, 0.7 - 5A, Current Limit Switch with Over-Voltage Clamp and Reverse Block, marking FG, QFN10:
https://www.monolithicpower.com/media/document/MP5016H_r1.0.pdf
https://images.anandtech.com/doci/12263/imgp0157.jpg
Author:  hdd_guru [ February 17th, 2023, 0:25 ]
You guys are a wealth of knowledge. Thank you so much. Will study and try. Thank you!
Best wishes to all.
Author:  DataLab RSA [ March 13th, 2023, 7:49 ]
did you found the short because last week I had the same problem with the same SSD and found the short next to one of the NAND units and just removed the shorted cap c88 and c91 they warmed up alot and managed to get access to all data. Will send picture later
