 Post subject: Microsoft surface soldered ssd recovery.
PostPosted: April 5th, 2023, 10:11
Is there anyone that can recover MS Surface Pro 1796 with a soldered ssd?
Gordon
 Post subject: Re: Microsoft surface soldered ssd recovery.
PostPosted: April 14th, 2023, 23:00
Make your own board, which has been tested and works fine. PCB thickness is 0.8MM! Gerber and BOM list are in the compressed package. Supported SSD manufacturers are: Toshiba and Intel.
If you have a Samsung or SK Hynix chip, please don't use it. It is recommended to buy a finished SSD to remove the chip and leave the circuit board for use.
pay attention! Samsung's chip package has a double-layer structure, and it is almost impossible to disassemble it perfectly with a heat gun. Please use an infrared heating table to assist in heating the bottom surface and adjust the correct temperature curve before implementing it. Once the chip is delaminated, it will be a tricky thing, I think 99% of the maintenance personnel will not be able to restore
Gerber_BGA291_nvmeSSD.rar [57.16 KiB]
Downloaded 208 times
http://flash-matrix.com/
PostPosted: April 15th, 2023, 7:40
Reach out to Krzys at Data Recue Labs.
PostPosted: April 17th, 2023, 12:17
More than likely it will be BitLocker encrypted. Make sure the client has his recovery key.
PostPosted: April 18th, 2023, 6:08
Can you not fix the Surface ? Whats the issue ?
