Page 1 of 1
Sandisk X400 completely dead
Posted: February 27th, 2023, 11:57
by Nicky
any help what to start checking completely dead.
Re: Sandisk X400 completely dead
Posted: February 27th, 2023, 12:13
by fzabkar
Posted: November 10th, 2023, 8:38
by Hughespc
Have the same drive, can anybody assist with circuit diagram or repair. Drive does not power on, have identical drive as a donor, hoping to repair power supply rather than transplant storage chips to other device.
Posted: November 10th, 2023, 11:22
by Lardman
There are no diagrams available.
How are you check if the drive is powering on? Start with resistance to ground on the power rails and the voltages at the pmic and comparing the voltages on the donor.
Alternatively I know a good place you can send it
Posted: November 10th, 2023, 13:05
by fzabkar
Hughespc wrote:Have the same drive, can anybody assist with circuit diagram or repair. Drive does not power on, have identical drive as a donor, hoping to repair power supply rather than transplant storage chips to other device.
Posted: November 11th, 2023, 7:45
by Hughespc
fzabkar wrote:Hughespc wrote:Have the same drive, can anybody assist with circuit diagram or repair. Drive does not power on, have identical drive as a donor, hoping to repair power supply rather than transplant storage chips to other device.
Measured the voltages at these points and they same on working drive.
Posted: November 12th, 2023, 13:13
by fzabkar
There are two pads (at the top right corner of the first photo) which could be the safe mode shorting points. There appears to be a pullup resistor at one pad, so I expect that it would be electrically safe to short these pads. If the SSD identifies itself in safe mode, then this will at least tell you whether the controller has basic sanity.
