| I can't format sd 128 sandisk http://forum.hddguru.com/viewtopic.php?f=10&t=43232 |
Page 1 of 1 |
| Author: | silicon300 [ March 31st, 2023, 0:22 ] |
| Post subject: | I can't format sd 128 sandisk |
I can't format sd 128 sandisk. I already tried everything, use the hdd low level format 4.4 It formats to the end, but then I open the drive and there are all the files. I don't know what to do. |
| Author: | fzabkar [ March 31st, 2023, 13:22 ] |
| Post subject: | Re: I can't format sd 128 sandisk |
Maybe the drive has failed and is now in read-only mode? |
| Author: | silicon300 [ March 31st, 2023, 17:55 ] |
I already tried that and nothing, I had it shared as storage with my cell phone and encrypted. |
| Author: | Arch Stanton [ March 31st, 2023, 18:18 ] |
| Author: | silicon300 [ March 31st, 2023, 18:20 ] |
Not read mode |
| Author: | Arch Stanton [ March 31st, 2023, 18:41 ] |
It failed. You can no longer write to it. Firmware switched to read only mode. It's dead, Jim. |
| Author: | silicon300 [ March 31st, 2023, 18:52 ] |
the sd is full, I already backed up the files with a special program. I delete a file, it deletes it and then it appears again. the common format on the pc gives me an error. |
| Author: | Arch Stanton [ March 31st, 2023, 18:53 ] |
Yes, because deletion implies writing to the card. It's kaput! |
| Author: | silicon300 [ March 31st, 2023, 18:55 ] |
There is nothing to do, try some other option. |
