 Post subject: I can't format sd 128 sandisk
PostPosted: March 31st, 2023, 0:22
I can't format sd 128 sandisk.
I already tried everything, use the hdd low level format 4.4
It formats to the end, but then I open the drive and there are all the files.
I don't know what to do.
 Post subject: Re: I can't format sd 128 sandisk
PostPosted: March 31st, 2023, 13:22
Maybe the drive has failed and is now in read-only mode?
PostPosted: March 31st, 2023, 17:55
I already tried that and nothing, I had it shared as storage with my cell phone and encrypted.
PostPosted: March 31st, 2023, 18:18
PostPosted: March 31st, 2023, 18:20
Not read mode
PostPosted: March 31st, 2023, 18:41
It failed. You can no longer write to it. Firmware switched to read only mode. It's dead, Jim.
PostPosted: March 31st, 2023, 18:52
the sd is full, I already backed up the files with a special program. I delete a file, it deletes it and then it appears again. the common format on the pc gives me an error.
PostPosted: March 31st, 2023, 18:53
Yes, because deletion implies writing to the card. It's kaput!
PostPosted: March 31st, 2023, 18:55
There is nothing to do, try some other option.
Users browsing this forum: No registered users and 144 guests
