Dolphin adaptor for Apple A1708 SSD
http://forum.hddguru.com/viewtopic.php?f=10&t=43234
Author:  fzabkar [ March 31st, 2023, 14:20 ]
Post subject:  Dolphin adaptor for Apple A1708 SSD
Does anyone have this adaptor? If so, would they be willing to try a simple, safe, no-cost modification to allow it to support those SSDs with the "big inductor at the top left"?
https://www.dolphindatalab.com/product/macbook-pro-a1708-pcie-ssd-recovery-adapter-smart/
If anyone has the other SSD (small inductors), would they be willing to post photos of the innards?
Author:  fzabkar [ April 1st, 2023, 17:42 ]
Post subject:  Re: Dolphin adaptor for Apple A1708 SSD
I have collated some information on this SSD and the various adaptors:
https://www.hddoracle.com/viewtopic.php?f=106&t=3252
Author:  suricate.ch [ April 4th, 2023, 16:41 ]
I have it. Let me know how i can help you.
Author:  fzabkar [ April 4th, 2023, 16:52 ]
I contacted Dolphin and asked them if connecting an external 12V supply to pins 1, 2 and 3 of the adaptor would enable it to work with the "big inductor" SSD. They said it wouldn't work. :-(
Ace's adaptor is very clever. It uses pins 1 and 2 of the SATA power connector (these pins are "reserved" or unused) to control the SSD via I2C. When the SSD becomes unresponsive, Ace's Portable can toggle the SSD's hardware reset pin(s). I doubt that Dolphin's adaptor is able to do this, but a look inside the metal can would be very useful. Also, a photo of both sides of the m.2 adaptor would provide a lot of clues, too.
I think Ace's Portable might be able to control other devices via pins 1 and 2. I expect that the unit either has a dedicated I2C host controller, or perhaps Ace bitbangs a couple of GPIO pins to simulate an I2C port.
Author:  csava [ April 6th, 2023, 11:26 ]
U1 is the 53rd and 55th pins that NB3N3002DTG connects to the M.2 interface, used as an external clock generator for PCIE host. U2 is TCA9534PWR, an 8-bit expansion chip from Texas Instruments that expands to 16 bits of I/O, used to distinguish whether the hard drive inserted into the interface is using SATA or NVME protocol. Power on/off control is handled by the P3 Portable host. As for determining whether SSDs are frozen, I think it should not be a hardware issue with the converter but rather a status register in either NVME or SATA protocol.
Author:  fzabkar [ April 6th, 2023, 12:39 ]
Thanks, but that's a different adaptor.
Author:  fzabkar [ April 8th, 2023, 17:29 ]
Can you show us photos of the m.2 adaptor and a photo of the inside of the metal can?
Author:  csava [ April 10th, 2023, 1:24 ]
make your own adapter :D
A1780.rar [5.84 MiB]
Downloaded 339 times
Author:  fzabkar [ April 10th, 2023, 13:01 ]
Thanks. I have already collated the same information at my HDD Oracle thread.
