| is there any software who can detect which flash is failing? http://forum.hddguru.com/viewtopic.php?f=10&t=43282 |
Page 1 of 1 |
| Author: | saronno [ April 21st, 2023, 14:10 ] |
| Post subject: | is there any software who can detect which flash is failing? |
I fix graphics card from time to time, and there there is a piece of software who is able to detect which memory chip is giving errors. So now I am wonder if there is something similar to detect a failing flash chip inside an ssd .... |
| Author: | sourcerer [ August 22nd, 2023, 4:41 ] |
| Post subject: | Re: is there any software who can detect which flash is fail |
Hi! My SSDDiag does a diagnostic of the various channels: https://github.com/thesourcerer8/ssddiag The big difference between GPU RAM and SSD Flash chips though is that flash chips are non volatile, so you would need to transfer the data to new chips, and I am not aware of such a solution for SSDs yet. For GPUs you just replace the DRAM chips. |
| Author: | Arch Stanton [ August 22nd, 2023, 10:29 ] |
sourcerer wrote: But this works with specific models only, right? |
| Author: | sourcerer [ September 4th, 2023, 8:40 ] |
Yes, it only works with specific models at the moment |
