Phison PS2251-50-F controller
http://forum.hddguru.com/viewtopic.php?f=10&t=43314
Author:  Needhelp [ May 2nd, 2023, 13:56 ]
Post subject:  Phison PS2251-50-F controller
Does anyone know if this controller stripes data across both NANDS in a flash drive with 2 NANDS (like a RAID)? Or does it dump to one NAND before using the other? Thanks
Author:  lcoughey [ May 2nd, 2023, 18:31 ]
Post subject:  Re: Phison PS2251-50-F controller
You could find your answer here.
http://www.pc-3000flash.com/solbase/task.php
Author:  csava [ May 4th, 2023, 23:14 ]
Whether to use the pair element depends on the firmware mode, not on the controller model. You have to actually analyze the corresponding case to get accurate information
Author:  arvika [ May 5th, 2023, 4:16 ]
Yes. Usually Block pair, than join by page. So it mix between both chips.
