ADATA UV350 USB Flash Drive
http://forum.hddguru.com/viewtopic.php?f=10&t=43316
Author:  hack3rcon [ May 3rd, 2023, 8:58 ]
Post subject:  ADATA UV350 USB Flash Drive
I have an ADATA UV350 and it is write protected. Its serial number is "1216789504" and "G64G". I tried to download the recovery tool from http://www.adata.com/en/ss/usbdiy/, but the site is down :(.
The chipset information is:
Controller Vendor: SMI
Controller Part-Number: SM3265AC - ISP 210628-C01
Flash ID code: 2CC30832EA30 - Micron MT29F512G08EBLCE - 1CE/Single Channel [TLC-16K] -> Total Capacity = 1GB
I googled it and found https://www.usbdev.ru/files/smi/dynamptool/ website. I downloaded "Star_SM3265series_U0708.rar" file and tried to format the flash drive.After it, my USB flash size is 16GB, but it was 64GB.
Why? What is the problem?
Thank you.
Author:  labtech [ May 4th, 2023, 11:19 ]
Post subject:  Re: ADATA UV350 USB Flash Drive
Your location is in space, so it trying to fix is useless.
The flash chip is likely degraded enough, making it work in read-only mode. Eventually it may not work at all.
Adata uses low quality chips.
This article may help give a glimpse on why this is happening:
https://www.datarecoveryguru.com/edu/20 ... ps-quality
Author:  hack3rcon [ May 6th, 2023, 1:37 ]
Thank you so much for your reply.
I thought I ran the program wrong.
