 Post subject: Kioxia CM6 15.36TB suddenly showing 1600GB capacity
PostPosted: May 13th, 2023, 16:48
Hello, I've briefly owned a Kioxia CM6 15.36TB, was working fine at full 15.36TB capacity, then PC froze and after reboot I noticed total capacity showing 1600GB, SMART table wiped, and it can no longer be formatted or secure-erased even at 1600GB. Unclear what caused this, if firmware is corrupt, etc. Firmware for these drives is nearly impossible to find online since it's an enterprise SSD, but I tried flashing from one of its internal firmware slots, and it refuses the command.
I'm assuming it's a paperweight at this point, but if anyone has any insight I'd appreciate it. Output from nvme-cli id-ctrl is below.
ser@ws:~$ sudo nvme id-ctrl -H /dev/nvme0
NVME Identify Controller:
vid       : 0x1e0f
ssvid     : 0x1e0f
sn        : 81X0A029TD29
mn        : KCM6XRUL15T3
fr        : D401
rab       : 2
ieee      : 8ce38e
cmic      : 0
  [3:3] : 0   ANA not supported
  [2:2] : 0   PCI
  [1:1] : 0   Single Controller
  [0:0] : 0   Single Port
mdts      : 13
cntlid    : 0x1
ver       : 0x10400
rtd3r     : 0xf42400
rtd3e     : 0xf42400
oaes      : 0x300
  [31:31] : 0   Discovery Log Change Notice Not Supported
  [27:27] : 0   Zone Descriptor Changed Notices Not Supported
  [15:15] : 0   Normal NSS Shutdown Event Not Supported
  [14:14] : 0   Endurance Group Event Aggregate Log Page Change Notice Not Supported
  [13:13] : 0   LBA Status Information Notices Not Supported
  [12:12] : 0   Predictable Latency Event Aggregate Log Change Notices Not Supported
  [11:11] : 0   Asymmetric Namespace Access Change Notices Not Supported
  [9:9] : 0x1   Firmware Activation Notices Supported
  [8:8] : 0x1   Namespace Attribute Changed Event Supported
ctratt    : 0
  [15:15] : 0   Extended LBA Formats Not Supported
  [14:14] : 0   Delete NVM Set Not Supported
  [13:13] : 0   Delete Endurance Group Not Supported
  [12:12] : 0   Variable Capacity Management Not Supported
  [11:11] : 0   Fixed Capacity Management Not Supported
  [10:10] : 0   Multi Domain Subsystem Not Supported
  [9:9] : 0   UUID List Not Supported
  [7:7] : 0   Namespace Granularity Not Supported
  [5:5] : 0   Predictable Latency Mode Not Supported
  [4:4] : 0   Endurance Groups Not Supported
  [3:3] : 0   Read Recovery Levels Not Supported
  [2:2] : 0   NVM Sets Not Supported
  [1:1] : 0   Non-Operational Power State Permissive Not Supported
  [0:0] : 0   128-bit Host Identifier Not Supported
rrls      : 0
cntrltype : 0
  [7:2] : 0   Reserved
  [1:0] : 0   Controller type not reported
fguid     :
crdt1     : 0
crdt2     : 0
crdt3     : 0
nvmsr     : 1
  [1:1] : 0   NVM subsystem Not part of an Enclosure
  [0:0] : 0x1   NVM subsystem part of an Storage Device
vwci      : 255
  [7:7] : 0x1   VPD Write Cycles Remaining field is valid.
  [6:0] : 0xfe   VPD Write Cycles Remaining
mec       : 3
[7:2] : 0x3c   Reserved
  [1:1] : 0x1   NVM subsystem contains a Management Endpoint on a PCIe port
  [0:0] : 0x1   NVM subsystem contains a Management Endpoint on an SMBus/I2C port
oacs      : 0x1f
  [10:10] : 0   Lockdown Command and Feature Not Supported
  [9:9] : 0   Get LBA Status Capability Not Supported
  [8:8] : 0   Doorbell Buffer Config Not Supported
  [7:7] : 0   Virtualization Management Not Supported
  [6:6] : 0   NVMe-MI Send and Receive Not Supported
  [5:5] : 0   Directives Not Supported
  [4:4] : 0x1   Device Self-test Supported
  [3:3] : 0x1   NS Management and Attachment Supported
  [2:2] : 0x1   FW Commit and Download Supported
  [1:1] : 0x1   Format NVM Supported
  [0:0] : 0x1   Security Send and Receive Supported
acl       : 3
aerl      : 3
frmw      : 0x14
  [5:5] : 0   Multiple FW or Boot Update Detection Not Supported
  [4:4] : 0x1   Firmware Activate Without Reset Supported
  [3:1] : 0x2   Number of Firmware Slots
  [0:0] : 0   Firmware Slot 1 Read/Write
lpa       : 0xe
  [6:6] : 0   Telemetry Log Data Area 4 Not Supported
  [5:5] : 0   LID 0x0, Scope of each command in LID 0x5, 0x12, 0x13 Not Supported
  [4:4] : 0   Persistent Event log Not Supported
  [3:3] : 0x1   Telemetry host/controller initiated log page Supported
  [2:2] : 0x1   Extended data for Get Log Page Supported
  [1:1] : 0x1   Command Effects Log Page Supported
  [0:0] : 0   SMART/Health Log Page per NS Not Supported
elpe      : 255
npss      : 4
avscc     : 0
  [0:0] : 0   Admin Vendor Specific Commands uses Vendor Specific Format
apsta     : 0
  [0:0] : 0   Autonomous Power State Transitions Not Supported
wctemp    : 0
[16:0] : -273 C (0 Kelvin)   Warning temperature (WCTEMP)
cctemp    : 0
[16:0] : -273 C (0 Kelvin)   Critical temperature (CCTEMP)
mtfa      : 0
hmpre     : 0
hmmin     : 0
tnvmcap   : 1600321314816
unvmcap   : 0
rpmbs     : 0
[31:24]: 0   Access Size
[23:16]: 0   Total Size
  [5:3] : 0   Authentication Method
  [2:0] : 0   Number of RPMB Units
edstt     : 30
dsto      : 1
fwug      : 255
kas       : 0
hctma     : 0x1
  [0:0] : 0x1   Host Controlled Thermal Management Supported
mntmt     : 340
mxtmt     : 350
sanicap   : 0x3
  [31:30] : 0   Additional media modification after sanitize operation completes successfully is not defined
  [29:29] : 0   No-Deallocate After Sanitize bit in Sanitize command Supported
    [2:2] : 0   Overwrite Sanitize Operation Not Supported
    [1:1] : 0x1   Block Erase Sanitize Operation Supported
    [0:0] : 0x1   Crypto Erase Sanitize Operation Supported
hmminds   : 0
hmmaxd    : 0
nsetidmax : 0
endgidmax : 0
anatt     : 0
anacap    : 0
  [7:7] : 0   Non-zero group ID Not Supported
  [6:6] : 0   Group ID does not change
  [4:4] : 0   ANA Change state Not Supported
  [3:3] : 0   ANA Persistent Loss state Not Supported
  [2:2] : 0   ANA Inaccessible state Not Supported
  [1:1] : 0   ANA Non-optimized state Not Supported
  [0:0] : 0   ANA Optimized state Not Supported
anagrpmax : 0
nanagrpid : 0
pels      : 0
domainid  : 0
megcap    : 0
sqes      : 0x66
  [7:4] : 0x6   Max SQ Entry Size (64)
  [3:0] : 0x6   Min SQ Entry Size (64)
cqes      : 0x44
  [7:4] : 0x4   Max CQ Entry Size (16)
  [3:0] : 0x4   Min CQ Entry Size (16)
maxcmd    : 0
nn        : 1
oncs      : 0x7f
  [8:8] : 0   Copy Not Supported
  [7:7] : 0   Verify Not Supported
  [6:6] : 0x1   Timestamp Supported
  [5:5] : 0x1   Reservations Supported
  [4:4] : 0x1   Save and Select Supported
  [3:3] : 0x1   Write Zeroes Supported
  [2:2] : 0x1   Data Set Management Supported
  [1:1] : 0x1   Write Uncorrectable Supported
  [0:0] : 0x1   Compare Supported
fuses     : 0x1
  [0:0] : 0x1   Fused Compare and Write Supported
fna       : 0x6
  [3:3] : 0   FormatNVM Broadcast NSID (FFFFFFFFh) Supported
  [2:2] : 0x1   Crypto Erase Supported as part of Secure Erase
  [1:1] : 0x1   Crypto Erase Applies to All Namespace(s)
  [0:0] : 0   Format Applies to Single Namespace(s)
vwc       : 0
  [2:1] : 0   Support for the NSID field set to FFFFFFFFh is not indicated
  [0:0] : 0   Volatile Write Cache Not Present
awun      : 65535
awupf     : 0
icsvscc     : 0
  [0:0] : 0   NVM Vendor Specific Commands uses Vendor Specific Format
nwpc      : 0
  [2:2] : 0   Permanent Write Protect Not Supported
  [1:1] : 0   Write Protect Until Power Supply Not Supported
  [0:0] : 0   No Write Protect and Write Protect Namespace Not Supported
acwu      : 65535
ocfs      : 0
  [1:1] : 0   Controller Copy Format 1h Not Supported
  [0:0] : 0   Controller Copy Format 0h Not Supported
sgls      : 0xf0001
[21:21]: 0   Transport SGL Data Block Descriptor Not Supported
[20:20]: 0   Address Offsets Not Supported
[19:19]: 0x1   Metadata Pointer Containing SGL Descriptor is Supported
[18:18]: 0x1   SGL Length Larger than Buffer Supported
[17:17]: 0x1   Byte-Aligned Contig. MD Buffer Supported
[16:16]: 0x1   SGL Bit-Bucket Supported
[15:8] : 0   SGL Descriptor Threshold
  [2:2] : 0   Keyed SGL Data Block descriptor Not Supported
  [1:0] : 0x1   Scatter-Gather Lists Supported. No Dword alignment required.
mnan      : 0
maxdna    : 0
maxcna    : 0
subnqn    : nqn.2019-10.com.kioxia:KCM6XRUL15T3:81X0A029TD29
ioccsz    : 0
iorcsz    : 0
icdoff    : 0
fcatt     : 0
  [0:0] : 0   Dynamic Controller Model
msdbd     : 0
ofcs      : 0
  [0:0] : 0   Disconnect command Not Supported
ps    0 : mp:19.80W operational enlat:0 exlat:0 rrt:0 rrl:0
          rwt:0 rwl:0 idle_power:6.00W active_power:18.00W
ps    1 : mp:17.60W operational enlat:0 exlat:0 rrt:0 rrl:0
          rwt:1 rwl:1 idle_power:6.00W active_power:16.00W
ps    2 : mp:15.40W operational enlat:0 exlat:0 rrt:0 rrl:0
          rwt:2 rwl:2 idle_power:6.00W active_power:14.00W
ps    3 : mp:12.10W operational enlat:0 exlat:0 rrt:1 rrl:1
          rwt:3 rwl:3 idle_power:6.00W active_power:11.00W
ps    4 : mp:9.90W operational enlat:0 exlat:0 rrt:2 rrl:2
          rwt:4 rwl:4 idle_power:6.00W active_power:9.00W
 Post subject: Re: Kioxia CM6 15.36TB suddenly showing 1600GB capacity
PostPosted: May 14th, 2023, 15:42
I can't help, but I notice that the serial number looks strange. The manufacture date appears to be August 2021, but the code for the day of the month ("X") appears to be invalid.
Toshiba's warranty checker rejects your drive, presumably because it doesn't recognise the code for the part number ("TD29").
https://myapps.taec.toshiba.com/myapps/admin/jsp/webrma/addRequest1NoLogin.jsp
Toshiba HDD and SSD serial numbers:
http://www.hddoracle.com/viewtopic.php?f=45&t=3266
