| Kioxia CM6 15.36TB suddenly showing 1600GB capacity http://forum.hddguru.com/viewtopic.php?f=10&t=43336 |
Page 1 of 1 |
| Author: | djones [ May 13th, 2023, 16:48 ] |
| Post subject: | Kioxia CM6 15.36TB suddenly showing 1600GB capacity |
Hello, I've briefly owned a Kioxia CM6 15.36TB, was working fine at full 15.36TB capacity, then PC froze and after reboot I noticed total capacity showing 1600GB, SMART table wiped, and it can no longer be formatted or secure-erased even at 1600GB. Unclear what caused this, if firmware is corrupt, etc. Firmware for these drives is nearly impossible to find online since it's an enterprise SSD, but I tried flashing from one of its internal firmware slots, and it refuses the command. I'm assuming it's a paperweight at this point, but if anyone has any insight I'd appreciate it. Output from nvme-cli id-ctrl is below. Code: ser@ws:~$ sudo nvme id-ctrl -H /dev/nvme0
NVME Identify Controller: vid : 0x1e0f ssvid : 0x1e0f sn : 81X0A029TD29 mn : KCM6XRUL15T3 fr : D401 rab : 2 ieee : 8ce38e cmic : 0 [3:3] : 0 ANA not supported [2:2] : 0 PCI [1:1] : 0 Single Controller [0:0] : 0 Single Port mdts : 13 cntlid : 0x1 ver : 0x10400 rtd3r : 0xf42400 rtd3e : 0xf42400 oaes : 0x300 [31:31] : 0 Discovery Log Change Notice Not Supported [27:27] : 0 Zone Descriptor Changed Notices Not Supported [15:15] : 0 Normal NSS Shutdown Event Not Supported [14:14] : 0 Endurance Group Event Aggregate Log Page Change Notice Not Supported [13:13] : 0 LBA Status Information Notices Not Supported [12:12] : 0 Predictable Latency Event Aggregate Log Change Notices Not Supported [11:11] : 0 Asymmetric Namespace Access Change Notices Not Supported [9:9] : 0x1 Firmware Activation Notices Supported [8:8] : 0x1 Namespace Attribute Changed Event Supported ctratt : 0 [15:15] : 0 Extended LBA Formats Not Supported [14:14] : 0 Delete NVM Set Not Supported [13:13] : 0 Delete Endurance Group Not Supported [12:12] : 0 Variable Capacity Management Not Supported [11:11] : 0 Fixed Capacity Management Not Supported [10:10] : 0 Multi Domain Subsystem Not Supported [9:9] : 0 UUID List Not Supported [7:7] : 0 Namespace Granularity Not Supported [5:5] : 0 Predictable Latency Mode Not Supported [4:4] : 0 Endurance Groups Not Supported [3:3] : 0 Read Recovery Levels Not Supported [2:2] : 0 NVM Sets Not Supported [1:1] : 0 Non-Operational Power State Permissive Not Supported [0:0] : 0 128-bit Host Identifier Not Supported rrls : 0 cntrltype : 0 [7:2] : 0 Reserved [1:0] : 0 Controller type not reported fguid : crdt1 : 0 crdt2 : 0 crdt3 : 0 nvmsr : 1 [1:1] : 0 NVM subsystem Not part of an Enclosure [0:0] : 0x1 NVM subsystem part of an Storage Device vwci : 255 [7:7] : 0x1 VPD Write Cycles Remaining field is valid. [6:0] : 0xfe VPD Write Cycles Remaining mec : 3 [7:2] : 0x3c Reserved [1:1] : 0x1 NVM subsystem contains a Management Endpoint on a PCIe port [0:0] : 0x1 NVM subsystem contains a Management Endpoint on an SMBus/I2C port oacs : 0x1f [10:10] : 0 Lockdown Command and Feature Not Supported [9:9] : 0 Get LBA Status Capability Not Supported [8:8] : 0 Doorbell Buffer Config Not Supported [7:7] : 0 Virtualization Management Not Supported [6:6] : 0 NVMe-MI Send and Receive Not Supported [5:5] : 0 Directives Not Supported [4:4] : 0x1 Device Self-test Supported [3:3] : 0x1 NS Management and Attachment Supported [2:2] : 0x1 FW Commit and Download Supported [1:1] : 0x1 Format NVM Supported [0:0] : 0x1 Security Send and Receive Supported acl : 3 aerl : 3 frmw : 0x14 [5:5] : 0 Multiple FW or Boot Update Detection Not Supported [4:4] : 0x1 Firmware Activate Without Reset Supported [3:1] : 0x2 Number of Firmware Slots [0:0] : 0 Firmware Slot 1 Read/Write lpa : 0xe [6:6] : 0 Telemetry Log Data Area 4 Not Supported [5:5] : 0 LID 0x0, Scope of each command in LID 0x5, 0x12, 0x13 Not Supported [4:4] : 0 Persistent Event log Not Supported [3:3] : 0x1 Telemetry host/controller initiated log page Supported [2:2] : 0x1 Extended data for Get Log Page Supported [1:1] : 0x1 Command Effects Log Page Supported [0:0] : 0 SMART/Health Log Page per NS Not Supported elpe : 255 npss : 4 avscc : 0 [0:0] : 0 Admin Vendor Specific Commands uses Vendor Specific Format apsta : 0 [0:0] : 0 Autonomous Power State Transitions Not Supported wctemp : 0 [16:0] : -273 C (0 Kelvin) Warning temperature (WCTEMP) cctemp : 0 [16:0] : -273 C (0 Kelvin) Critical temperature (CCTEMP) mtfa : 0 hmpre : 0 hmmin : 0 tnvmcap : 1600321314816 unvmcap : 0 rpmbs : 0 [31:24]: 0 Access Size [23:16]: 0 Total Size [5:3] : 0 Authentication Method [2:0] : 0 Number of RPMB Units edstt : 30 dsto : 1 fwug : 255 kas : 0 hctma : 0x1 [0:0] : 0x1 Host Controlled Thermal Management Supported mntmt : 340 mxtmt : 350 sanicap : 0x3 [31:30] : 0 Additional media modification after sanitize operation completes successfully is not defined [29:29] : 0 No-Deallocate After Sanitize bit in Sanitize command Supported [2:2] : 0 Overwrite Sanitize Operation Not Supported [1:1] : 0x1 Block Erase Sanitize Operation Supported [0:0] : 0x1 Crypto Erase Sanitize Operation Supported hmminds : 0 hmmaxd : 0 nsetidmax : 0 endgidmax : 0 anatt : 0 anacap : 0 [7:7] : 0 Non-zero group ID Not Supported [6:6] : 0 Group ID does not change [4:4] : 0 ANA Change state Not Supported [3:3] : 0 ANA Persistent Loss state Not Supported [2:2] : 0 ANA Inaccessible state Not Supported [1:1] : 0 ANA Non-optimized state Not Supported [0:0] : 0 ANA Optimized state Not Supported anagrpmax : 0 nanagrpid : 0 pels : 0 domainid : 0 megcap : 0 sqes : 0x66 [7:4] : 0x6 Max SQ Entry Size (64) [3:0] : 0x6 Min SQ Entry Size (64) cqes : 0x44 [7:4] : 0x4 Max CQ Entry Size (16) [3:0] : 0x4 Min CQ Entry Size (16) maxcmd : 0 nn : 1 oncs : 0x7f [8:8] : 0 Copy Not Supported [7:7] : 0 Verify Not Supported [6:6] : 0x1 Timestamp Supported [5:5] : 0x1 Reservations Supported [4:4] : 0x1 Save and Select Supported [3:3] : 0x1 Write Zeroes Supported [2:2] : 0x1 Data Set Management Supported [1:1] : 0x1 Write Uncorrectable Supported [0:0] : 0x1 Compare Supported fuses : 0x1 [0:0] : 0x1 Fused Compare and Write Supported fna : 0x6 [3:3] : 0 FormatNVM Broadcast NSID (FFFFFFFFh) Supported [2:2] : 0x1 Crypto Erase Supported as part of Secure Erase [1:1] : 0x1 Crypto Erase Applies to All Namespace(s) [0:0] : 0 Format Applies to Single Namespace(s) vwc : 0 [2:1] : 0 Support for the NSID field set to FFFFFFFFh is not indicated [0:0] : 0 Volatile Write Cache Not Present awun : 65535 awupf : 0 icsvscc : 0 [0:0] : 0 NVM Vendor Specific Commands uses Vendor Specific Format nwpc : 0 [2:2] : 0 Permanent Write Protect Not Supported [1:1] : 0 Write Protect Until Power Supply Not Supported [0:0] : 0 No Write Protect and Write Protect Namespace Not Supported acwu : 65535 ocfs : 0 [1:1] : 0 Controller Copy Format 1h Not Supported [0:0] : 0 Controller Copy Format 0h Not Supported sgls : 0xf0001 [21:21]: 0 Transport SGL Data Block Descriptor Not Supported [20:20]: 0 Address Offsets Not Supported [19:19]: 0x1 Metadata Pointer Containing SGL Descriptor is Supported [18:18]: 0x1 SGL Length Larger than Buffer Supported [17:17]: 0x1 Byte-Aligned Contig. MD Buffer Supported [16:16]: 0x1 SGL Bit-Bucket Supported [15:8] : 0 SGL Descriptor Threshold [2:2] : 0 Keyed SGL Data Block descriptor Not Supported [1:0] : 0x1 Scatter-Gather Lists Supported. No Dword alignment required. mnan : 0 maxdna : 0 maxcna : 0 subnqn : nqn.2019-10.com.kioxia:KCM6XRUL15T3:81X0A029TD29 ioccsz : 0 iorcsz : 0 icdoff : 0 fcatt : 0 [0:0] : 0 Dynamic Controller Model msdbd : 0 ofcs : 0 [0:0] : 0 Disconnect command Not Supported ps 0 : mp:19.80W operational enlat:0 exlat:0 rrt:0 rrl:0 rwt:0 rwl:0 idle_power:6.00W active_power:18.00W ps 1 : mp:17.60W operational enlat:0 exlat:0 rrt:0 rrl:0 rwt:1 rwl:1 idle_power:6.00W active_power:16.00W ps 2 : mp:15.40W operational enlat:0 exlat:0 rrt:0 rrl:0 rwt:2 rwl:2 idle_power:6.00W active_power:14.00W ps 3 : mp:12.10W operational enlat:0 exlat:0 rrt:1 rrl:1 rwt:3 rwl:3 idle_power:6.00W active_power:11.00W ps 4 : mp:9.90W operational enlat:0 exlat:0 rrt:2 rrl:2 rwt:4 rwl:4 idle_power:6.00W active_power:9.00W |
| Author: | fzabkar [ May 14th, 2023, 15:42 ] |
| Post subject: | Re: Kioxia CM6 15.36TB suddenly showing 1600GB capacity |
I can't help, but I notice that the serial number looks strange. The manufacture date appears to be August 2021, but the code for the day of the month ("X") appears to be invalid. Toshiba's warranty checker rejects your drive, presumably because it doesn't recognise the code for the part number ("TD29"). https://myapps.taec.toshiba.com/myapps/admin/jsp/webrma/addRequest1NoLogin.jsp Toshiba HDD and SSD serial numbers: http://www.hddoracle.com/viewtopic.php?f=45&t=3266 |
