update firmware CBM2099E
http://forum.hddguru.com/viewtopic.php?f=10&t=43402
Author:  xyz [ June 12th, 2023, 6:36 ]
Post subject:  update firmware CBM2099E
Hello lads
I need to update the firmware of an external drive, but I can't find the right utility and firmware
Can anyone help me?
I write below the result of ChipGenius
thank you very much
Description: [D:]Dispositivo di archiviazione di massa USB(General UDisk)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 100mA
USB Device ID: VID = 048D PID = 04D2
Device Vendor: General
Device Name: UDisk
Device Revision: 0100
Manufacturer: General
Product Model: UDisk
Product Revision: 5.00
Controller Vendor: ChipsBank
Controller Part-Number: CBM2099E - [2019-11-11]
Flash ID code: AD5E28221090 - Hynix - 1CE/Single Channel [TLC]
Possible Flash Part-Number
Unknown
Flash ID mapping table
[Channel 0] [Channel 1]
AD5E28221090 --------
Author:  xyz [ June 22nd, 2023, 10:02 ]
Post subject:  Re: update firmware CBM2099E
Up please
Author:  NikolayIslentev [ June 22nd, 2023, 11:56 ]
Hello. Search for Chipsbank CBM2099 UMPTool on usbdev. One of them should work, but you may need to short testpoints on the flash to get it into factory mode.
