| 90430VM330 -PMIC Sandisk SDSSDE61-500G http://forum.hddguru.com/viewtopic.php?f=10&t=43411 |
Page 1 of 3 |
| Author: | fzabkar [ June 14th, 2023, 16:28 ] |
| Post subject: | Re: 90430VM330 -PMIC Sandisk SDSSDE61-500G |
Quote: PMIC is 9040VM339. For this chip, I can find datasheet. Can you upload it? |
| Author: | suricate.ch [ June 14th, 2023, 16:50 ] |
I tought that was datasheet but looks like it's not enough https://www.ariat-tech.com/parts/wurth- ... 040VM339-T |
| Author: | fzabkar [ June 14th, 2023, 16:53 ] |
Just another scumbag web site with phony links to "datasheets". They've worked out that people looking for datasheets will search for PDFs, so they stick their spam inside their own PDFs. |
| Author: | suricate.ch [ June 14th, 2023, 16:56 ] |
It looks like those are made by qorvo but not easy to get the datasheet. https://www.qorvo.com/products/power-so ... ular-pmics |
| Author: | fzabkar [ June 14th, 2023, 17:02 ] |
Active Semiconductor was the original maker, but they were acquired by Qorvo. Even if you were able to match the ACT90430VM part of the name, the last 3 digits define a custom voltage profile and power-up sequence. In other words, even if the pinouts are a match, it could be that the voltages and power sequences are different. |
| Author: | suricate.ch [ June 14th, 2023, 17:05 ] |
Thank you for the clarification. So I better try to find exact same model then. I've tried Mouser, digikey, Farnell no luck yet. |
| Author: | fzabkar [ June 14th, 2023, 17:13 ] |
When searching for datasheets, I use this custom search to filter out most spam: https://www.google.com/search?q=filetype:pdf+"absolute+maximum"+LM317 |
| Author: | suricate.ch [ June 15th, 2023, 1:00 ] |
Great tips, thank you ! |
| Author: | Lardman [ June 15th, 2023, 2:43 ] |
suricate.ch wrote: Thank you for the clarification. So I better try to find exact same model then. Donor roulette on ebay is probably safest but they're also available on aliexpress if you want to risk it.
| Author: | fzabkar [ June 15th, 2023, 3:01 ] |
See the custom voltage profiles on page 4: https://www.qorvo.com/products/d/da006800 |
| Author: | Lardman [ June 15th, 2023, 3:03 ] |
Also appears to have been used on WD BLUE SN550 - which should make finding them on ebay by checking the images easier. |
| Author: | fzabkar [ June 15th, 2023, 3:14 ] |
Did you check the MOSFET switch adjacent to the diode? That's a common problem. |
| Author: | suricate.ch [ June 15th, 2023, 4:17 ] | ||
| Post subject: | Re: 90430VM330 -PMIC Sandisk SDSSDE61-500G | ||
Thansk for the input, it could be Mosfet as well. All pads marked in Orange have 3.29V and the filter with green line means they "bip" if I put probe on each side. It's not easy to test without removing components. Do you beleive I should try to remove the Mosfet (marked AF) and then try to inject voltage on the output ?
| Author: | Ihab [ June 15th, 2023, 4:52 ] |
Hi, i have right now the same Problem.. like a year ag oi had the same problem and had a donor. I replaced like every component around the chip but still didnt work... Now i have the same problem and i checked the values with a working donor und its nearly the same... |
| Author: | Ihab [ June 15th, 2023, 5:01 ] |
suricate.ch, I get everywere 3.42V.. even on the diode |
| Author: | fzabkar [ June 15th, 2023, 6:20 ] |
Since you are getting 3.3V around the PMIC, the MOSFET must be OK. |
| Author: | suricate.ch [ June 15th, 2023, 10:10 ] |
@Ihab, did you replace PMIC with exact same model ? |
| Author: | Ihab [ June 15th, 2023, 10:12 ] |
suricate.ch, no. That was the only thing i didnt replaced in this area. |
| Author: | suricate.ch [ June 15th, 2023, 10:49 ] |
I am pretty sure that's the culprit now. |
| Page 1 of 3 | All times are UTC - 5 hours [ DST ] |
