 Post subject: Micron nvme . Nothing on pc
PostPosted: June 17th, 2023, 6:24
micron nvme . Nothing on pc. some parts heating.
Need advice
Sexy Womans from your town
 Post subject: Re: Micron nvme . Nothing on pc
PostPosted: June 17th, 2023, 12:07
The cap is shorted to gnd on both pads? Check the other caps with in same column, so you know which pad is GND and then lift the other side.
PostPosted: June 17th, 2023, 12:15
If you have already identified the shorted cap in picture #3 then removed it and check resistance of the rails to ground to see if the short is gone.
... wish people sent me drives with just shorted caps.
PostPosted: June 18th, 2023, 4:30
HaaHaa ,
Well you are a budding Data Recovery Expert in The UK ,i love your spirit of working .
PostPosted: June 20th, 2023, 4:05
suricate.ch wrote:
The cap is shorted to gnd on 1-both pads? Check the 2other caps with in same column, so you know which pad is GND and then lift the other side.
1 Yes .
2 Other caps normal. not shorted
