| Chances of data recovery. http://forum.hddguru.com/viewtopic.php?f=10&t=43565 |
Page 1 of 1 |
| Author: | JohnnyBoyK [ August 15th, 2023, 18:37 ] |
| Post subject: | Chances of data recovery. |
Hi I have a Image of Intel 512GB m2 SSD drive that was created with HDDSuperClone. When I open the image to browse the files I see the modified dates at 2019. I don't see any current files. I check the software distribution folder and the files in there were at 2019. It almost looks like the system did a restore to factory settings. The customer states that she did not do a system reset. Do you think if I send the drive out that it could be recovered? |
| Author: | lcoughey [ August 15th, 2023, 21:55 ] |
| Post subject: | Re: Chances of data recovery. |
Is it an Optane SSD? |
| Author: | JohnnyBoyK [ August 15th, 2023, 21:56 ] |
lcoughey wrote: Is it an Optane SSD? yes |
| Author: | digisupport [ August 16th, 2023, 1:37 ] |
Maybe recovery is possible. Your drive is actually two drives a, 32 GB Optane part and a 512 GB SSD storage. |
| Author: | pclab [ August 17th, 2023, 9:14 ] |
digisupport wrote: Maybe recovery is possible. Your drive is actually two drives a, 32 GB Optane part and a 512 GB SSD storage. How to read the Optane memory that's on the same SSD PCB? |
| Author: | osity [ March 7th, 2024, 10:48 ] |
We have been able to solve these. |
| Author: | labtech [ March 7th, 2024, 12:16 ] |
@JohnnyBoyK Need more info... How much total data is on the volume you are looking at? If it is much lower than 50GB, you are probably looking at the factory image volume. If it is in the 50GB-60GB range, then it is probably a fresh Windows installation, or a restore as you may suspect. Are you looking in the Users folder that should contain the main user profile? Maybe if you could show us what volumes are showing and their capacity in DMDE, R-Studio, UFS, we could make more sense of what is going on. |
