SanDisk Ultra 64GB MicroSD Pin Layout
http://forum.hddguru.com/viewtopic.php?f=10&t=43618
Author:  Ihab [ August 30th, 2023, 5:00 ]
Post subject:  SanDisk Ultra 64GB MicroSD Pin Layout
Hello guys!
I have this SD Card and it wont be recognized.. it doesnt have a short.
I wanted to work with the PC3K Flash. But the PC3K Flash forum Database dont have the PinLayout for this SD kart... maybe someone have it or can tell me where i can find it? I am rady to buy it.
Or does have someone other Ideas i could try?
Thank you!
Author:  melvin [ August 30th, 2023, 5:04 ]
Post subject:  Re: SanDisk Ultra 64GB MicroSD Pin Layout
That's a standard 7x3 and must be in PC3000 database.
Author:  Ihab [ August 30th, 2023, 5:22 ]
melvin, Thanks for your reply! So every 7x3 like this example are the same? I also have another SanDisk 64GB SD with 7x3 but the PINways are a biit different.. i also found one ont the database but also with other PINways. (sorry, i am new at the monolyth)
Author:  melvin [ August 30th, 2023, 5:25 ]
Sandisks 7x3 are all the same. Check VCC/ GND position with multimeter/ tracks. Compare it with pictures in the database.
Author:  Ihab [ August 30th, 2023, 5:26 ]
melvin, Thats a very good information. Thank you very much!
