Hello again. After some Time i have done some investigations and measurements. Btw. i'm not an expert more a bloody beginner and have not much expertise in electronics.
I added some photos and tried to match your sheets to the IC components. I hope this make sense. Also made a photo of the U74.
But to be honest. I Don't know how to continue. Btw. It is normal that the Sandforce chips is getting hot?
* U1: 35 RV5
* * NIS5135, 3.6A 5V Resettable Electronic Fuse, marking 35:
https://www.onsemi.com/pub/Collateral/NIS5135-D.PDF=> I had the idea to check if the enable pin is high. Which seems to be true. Does this make sense?
* U2: NFFF
* * TXS0101DBVR, Texas Instruments, 1-Bit Bidirectional Voltage-Level Shifter for Open-Drain and Push-Pull Application, marking NFFF, SOT-23-6:
https://www.ti.com/lit/gpn/txs0101=> I had the idea to check if the enable pin is high. Which seems to be true. Also measured the Voltage of VCC_A and VCC_B which are the same. Does this make sense? I expected that the component is converting signals between A and B while having different voltage levels. But i can also misunderstand the usage of this ic.
* U5: D7U231
* * MP28258DD, Monolithic Power, 3A, 4.2V - 20V Input, Synchronous Step-down Converter, marking AAA, QFN12:
https://www.monolithicpower.com/pub/med ... _r1.14.pdf=> Here i have no idea. The (amount of) Pins look different.
* U8: 8807 8V2D12
* * APW8807, Anpec, Synchronous Buck Converter, 8A, 6V - 28Vin, marking 8807, TQFN3x3-16A:
https://usermanual.wiki/Document/apw880 ... 995101.pdf=> Here i have also no idea. The (amount of) Pins look different.
* U74: I4BCA
I hope this information is helpful. Found soldering joins which don't look very clean. But don't know if this is normal. After that i gave everything a clean with IPA.
