Intel SATA SSD 300 (180GB) - Dead - PCB Repair
Posted: September 11th, 2023, 16:12
Hello everyone,
while googleing i found this forum where i hopefully find someone who can help me out with my problem. Today my SSD drive died. I rebooted my server and unfortunately my hdd is not showing up anymore. Not being recognized by the bios.
When i plug the hdd in (via usb sata) adapter the only thing getting really hot is the sandforce sf-2281 chip. With continuous power draw of rougly 2.8W.
Was hoping someone here might have some experience with this model. If there are common failures or can help me tracing down the issue.
What i have done so far.
* Visual inspection. Have not found any burned component.
* Searching full short. Have not found a full short to Ground.
* Taking some more or less random measurements
* * In the picture i attached i found two parts of the circuit looking similar.
* * I assumed that the voltage resistance to ground should be the same. This is not the case.
* * Some of the resistors have 20Ohm to Ground on one side and 0Ohm on the other side. While the other similar part has 0Ohm on one side and a way more on the other side.
* * While randomly meassuring capacitors to ground this is similar on other capacitors.
The Voltage in the red marked parts is also different. ~1.08Volt on one part while ~2.8Volt on the other similar part.
Thanks in advance
Thanks in advance
