| Seagate XF1230 ata password unlock? http://forum.hddguru.com/viewtopic.php?f=10&t=43659 |
Page 1 of 1 |
| Author: | RiceCheese [ September 11th, 2023, 16:51 ] |
| Post subject: | Seagate XF1230 ata password unlock? |
I am at my end of the rope of trying to unlock this drive. I have tried with MHDD, but i think i need a motherboard with a sata controller that supports ide mode to use it. After trying all computers i can get my hands on, i couldn't find any that can do it. I am currently trying with Vitoria but the security manager option shows disabled in API so i still can't unlock it. Is it actually possible to unlock it? What should i be using to do it? At this point i have almost already given up on the data on it, so even just whiping it would be an option. Thanks in advanced! |
| Author: | fzabkar [ September 11th, 2023, 17:06 ] |
| Post subject: | Re: Seagate XF1230 ata password unlock? |
How did you set the ATA password? Was the SSD in a laptop? Note that your password may be encoded by the laptop as keyboard scan codes or some other method. |
| Author: | RiceCheese [ September 11th, 2023, 17:59 ] |
fzabkar wrote: How did you set the ATA password? Was the SSD in a laptop? Note that your password may be encoded by the laptop as keyboard scan codes or some other method. I've got it inside a second hand homeserver, after using it for about a year, it locked itself after a crash and windows restart. |
| Author: | fzabkar [ September 11th, 2023, 18:27 ] |
Is it possible that this is not a real ATA password, but that the SSD has failed and is now in some kind of "safe mode" or factory mode? Can you show us the SMART output from GSmartControl or Victoria? |
| Author: | RiceCheese [ September 11th, 2023, 19:34 ] |
fzabkar wrote: Is it possible that this is not a real ATA password, but that the SSD has failed and is now in some kind of "safe mode" or factory mode? Can you show us the SMART output from GSmartControl or Victoria? Code: smartctl 7.2 2020-12-30 r5155 [x86_64-w64-mingw32-w10-b19045] (sf-7.2-1)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Nytro XF1230 SATA SSD Device Model: XF1230-1A0960 Serial Number: 7CW0063N LU WWN Device Id: 5 000c50 0813b9b3e Firmware Version: ST200354 User Capacity: 960.197.124.096 bytes [960 GB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 (minor revision not indicated) SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Sep 12 01:31:01 2023 WEDT SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: ENABLED, PW level HIGH, **LOCKED** [SEC4] Read SMART Data failed: Input/output error === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 4 Comprehensive SMART error log 0x03 GPL R/O 5 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 2 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x30 GPL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (5 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (2 sectors) No self-tests have been logged. [To run self-tests, use: smartctl -t] Selective Self-tests/Logging not supported SCT Commands not supported if ATA Security is LOCKED Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 711 --- Lifetime Power-On Resets 0x01 0x010 4 45153 --- Power-on Hours 0x01 0x018 6 101394356554 --- Logical Sectors Written 0x01 0x020 6 405984805 --- Number of Write Commands 0x01 0x028 6 921345456293 --- Logical Sectors Read 0x01 0x030 6 1957683938 --- Number of Read Commands 0x01 0x038 6 3637010048 --- Date and Time TimeStamp 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 30 --- Current Temperature 0x05 0x010 1 - --- Average Short Term Temperature 0x05 0x018 1 - --- Average Long Term Temperature 0x05 0x020 1 43 --- Highest Temperature 0x05 0x028 1 16 --- Lowest Temperature 0x05 0x030 1 30 --- Highest Average Short Term Temperature 0x05 0x038 1 23 --- Lowest Average Short Term Temperature 0x05 0x040 1 28 --- Highest Average Long Term Temperature 0x05 0x048 1 23 --- Lowest Average Long Term Temperature 0x05 0x050 4 0 --- Time in Over-Temperature 0x05 0x058 1 70 --- Specified Maximum Operating Temperature 0x05 0x060 4 0 --- Time in Under-Temperature 0x05 0x068 1 0 --- Specified Minimum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 21948 --- Number of Hardware Resets 0x06 0x018 4 0 --- Number of Interface CRC Errors 0x07 ===== = = === == Solid State Device Statistics (rev 1) == 0x07 0x008 1 1 --- Percentage Used Endurance Indicator |||_ C monitored condition met ||__ D supports DSN |___ N normalized value SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x000a 2 1 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000d 2 0 Non-CRC errors within host-to-device FIS |
| Author: | fzabkar [ September 11th, 2023, 20:51 ] |
Quote: Read SMART Data failed: Input/output error It does look like some kind of failure at the firmware level, even though it looks good in every (?) other respect. I don't know how to bypass the "security" and recover your data, but there may be a way to recover your drive. I would need to see detailed photos of the PCB, though, if you would be prepared to try. |
| Author: | fzabkar [ September 12th, 2023, 16:38 ] |
Sorry, those images are impossible to work with. I'm interested in the 20-pin chip at the bottom left. I suspect this may be an MP5505 which would be involved in power loss data protection. I was thinking that we could disable this chip and force the SSD into "safe mode" or "error mode" This technique was successfully employed to unlock a Samsung enterprise SSD in a recent thread. |
| Author: | RiceCheese [ September 12th, 2023, 16:41 ] |
fzabkar wrote: Sorry, those images are impossible to work with. I'm interested in the 20-pin chip at the bottom left. I suspect this may be an MP5505 which would be involved in power loss data protection. I was thinking that we could disable this chip and force the SSD into "safe mode" or "error mode" This technique was successfully employed to unlock a Samsung enterprise SSD in a recent thread. Yes, it is a MPGE 5505 891 chip |
| Author: | fzabkar [ September 12th, 2023, 16:43 ] |
See this thread: https://forum.hddguru.com/viewtopic.php?f=10&t=39458 |
| Author: | RiceCheese [ September 12th, 2023, 16:46 ] |
fzabkar wrote: Ok, thank you very much! I will look it up. |
