HDD GURU FORUMS
http://forum.hddguru.com/
Wise CFast 2.0 256GB
http://forum.hddguru.com/viewtopic.php?f=10&t=43664
Page 1 of 1
Author:  Ihab [ September 13th, 2023, 8:01 ]
Post subject:  Wise CFast 2.0 256GB
Hello guys!
I have this Wise CFast 2.0. It is getting voltage and with short the PC3K is recognize the SSD with 4MB...
I ordered a new one to check the scematic layout but its a different PCB...
My problem is that i want to get the data, but the pc is not recognize the SSD.
I am not sure if its the controller or the NAND chips... i didnt find any shorts.. does anyone have any experience with a case like this?
Is reballing an option?
Thank you guys!
Author:  csava [ September 13th, 2023, 9:26 ]
Post subject:  Re: Wise CFast 2.0 256GB
http://www.flash-extractor.com/library/JMF/JMF670/
Author:  Ihab [ September 13th, 2023, 9:44 ]
csava, Hello, how does this helping me?
Author:  csava [ September 13th, 2023, 10:12 ]
The only solution for this controller chip is chip off
Author:  arvika [ September 14th, 2023, 1:42 ]
You need read chip at external reader and assembly the data. Usually swap or reballing not help, just makes bigger degradation of memory modules.
Author:  Ihab [ September 14th, 2023, 3:09 ]
csava, arvika, thank you guys! I work with the PC3K Flash.. i hope they have a solution for it...
Author:  arvika [ September 14th, 2023, 12:10 ]
I'm sceptic, but you can try ;)
Author:  Ihab [ September 15th, 2023, 3:14 ]
arvika, anything else to recomand?
Author:  arvika [ September 15th, 2023, 10:03 ]
For this case probably Flash Extractor or VNR will be the best.
http://www.phpbb.com/
