CARD IS LOCKED
September 30th, 2023, 9:22
Hello, I recently started working on data recovery from Flash devices, and I have pc3000 flash. I've been getting a lot of SD and MicroSD cards that give the error CARD_IS_LOCKED!
Only this month I got 3 cards. and all showed the same error, to the point that I recently thought that I have an issue with my adapters.
Is there a solution for such thing? keep in mind that I didn't read the dump since the database doesn't include such pinouts and some are ldpc so its pointless.
Screenshot 2023-09-30 162143.png (8.37 KiB) Viewed 6374 times
Re: CARD IS LOCKED
October 1st, 2023, 7:17
Have you tried using a healthy new card of the same model of any of the 3 cards you received to compare behavior?
Re: CARD IS LOCKED
October 1st, 2023, 8:19
Most of cases where a card has locked status is when they are damaged and the only solution is to read them via NAND protocol. Even when you get full ID. The same status you'll get in any tool like Easy Jtag with ISP connection.
Software shows locked status because it can't get any sector access so it thinks the card is locked.
Re: CARD IS LOCKED
October 2nd, 2023, 13:59
melvin wrote:Software shows locked status because it can't get any sector access so it thinks the card is locked.
Not quite, the host knows that the card is locked by checking its status (CMD13). Card can be lock/unlock sending command CMD42 but you need to know the password.
melvin wrote:Most of cases where a card has locked status is when they are damaged and the only solution is to read them via NAND protocol
...and yes probably the only method is NAND, but there are people who can bypass it in some cards.
More source:
Bypass:
https://media.defcon.org/DEF%20CON%2027/DEF%20CON%2027%20presentations/DEFCON-27-Nicolas-Oberli-Poking-the-S-in-SD-cards.PDF
About lock/unlock sd card:
https://media-www.micron.com/-/media/client/global/documents/products/technical-note/sd-cards/tnsd01_enable_sd_lock_unlock_in_linux.pdf?rev=03f03a6bc0f8435fafa93a8fc8e88988
Re: CARD IS LOCKED
October 2nd, 2023, 16:05
I'm not even close to your experience at your workshop but i never had a client that would be aware of any card locking or password. But every single dead SD/mSD i checked in Easy-jtag had a locked status. And basing on their condition as beeing read over NAND, i would not expect them to unlock properly if possible. True that a controler can do more than a read over NAND + ECC correction in any tool.
You guys never shared a case on FB where it was possible.
Re: CARD IS LOCKED
October 4th, 2023, 11:19
Thanks for the info everyone, appreciate it a lot
