| MTP camera is there a way to get direct access to sectors? http://forum.hddguru.com/viewtopic.php?f=10&t=43795 |
Page 1 of 1 |
| Author: | Jirbun [ October 31st, 2023, 14:49 ] |
| Post subject: | MTP camera is there a way to get direct access to sectors? |
Only MTP and PTP options are available on the device. Is there a way to get direct access to sectors without chip off? |
| Author: | fzabkar [ October 31st, 2023, 15:45 ] |
| Post subject: | Re: MTP camera is there a way to get direct access to sector |
Maybe. For example, a particular Garmin UPS defaults to MTP mode but can be switched to USB mass storage mode by using an undocumented method. |
| Author: | HaQue [ October 31st, 2023, 20:29 ] |
maybe something like this? https://github.com/JasonFerrara/jmtpfs Quote: Usage:
Run jmtpfs with a directory as a parameter, and it will mount to that directory the first MTP device it finds. You can then access the files on the device as if it were a normal disk. |
| Author: | Arch Stanton [ November 1st, 2023, 7:41 ] |
HaQue wrote: maybe something like this? https://github.com/JasonFerrara/jmtpfs Quote: Usage: Run jmtpfs with a directory as a parameter, and it will mount to that directory the first MTP device it finds. You can then access the files on the device as if it were a normal disk. I doubt this gives raw sector access. |
| Author: | Jirbun [ November 1st, 2023, 14:56 ] |
HaQue wrote: maybe something like this? https://github.com/JasonFerrara/jmtpfs Quote: Usage: Run jmtpfs with a directory as a parameter, and it will mount to that directory the first MTP device it finds. You can then access the files on the device as if it were a normal disk. It seems to be similar to this tool https://www.mtpdrive.com/index.html It mapping devices operating in MTP mode to a drive letter and you can only access files but no disk appears in disk\device management so there is no access to sectors. Thanks |
| Author: | fzabkar [ November 1st, 2023, 15:25 ] |
Perhaps you could give us a fighting chance to provide a non-generic response by telling us the model of the camera and/or the chipset that it uses? |
| Author: | Jirbun [ November 2nd, 2023, 15:18 ] |
I don't have the camera anymore the owner took it, he said he had to film something important. I told him the more you write new data more chance that it will not be possible to recover deleted files anymore. In any case it was no brand I don't know if it was possible to know the chipset without disassembling totally. |
