Sandisk X300 diagnostics
http://forum.hddguru.com/viewtopic.php?f=10&t=43798
Author:  athena [ November 2nd, 2023, 2:21 ]
Post subject:  Sandisk X300 diagnostics
Hi friends
I want to know how to diagnose SANDISK X300 M.2 SATA SSD. It has no detection and I think it has electronic issue.
I have basic electronic knowledge so can check voltages but lack anything about smd and signal tracing etc.
any help will be appreciated.
Author:  pclab [ November 2nd, 2023, 3:54 ]
Post subject:  Re: Sandisk X300 diagnostics
Can you see if anything is heating up?
Author:  digisupport [ November 2nd, 2023, 7:07 ]
Is this a clients drive or your own drive you are planning to experiment on ?
I would start to compare measurement from a working identical drive. Maybe check if it IDs in safe mode.
Author:  athena [ November 2nd, 2023, 8:56 ]
hi pclab
Yes I have checked it momentarily , its not getting heated up. Physical inspection also doesn't show any burn marks.I think something is shorted.
Thanks.
Author:  athena [ November 2nd, 2023, 9:00 ]
Hi digisupport
Its my clients ssd. I don't have identical one. I have asked client to provide the same as they have similar drives. I have a pc3k-udma only so can't take it in safe mode. I am trying to get schematics also.
Author:  fzabkar [ November 5th, 2023, 13:20 ]
Perhaps you should outsource these jobs to an electronics technician? I would think there would be plenty such people in India.
If you do find a circuit diagram, please let us know. I would try to help you, but your photo is blacker than Donald Trump's heart.
Author:  athena [ November 5th, 2023, 23:58 ]
hi fzabkar
Thanks for your help. Yes photo is not clear ,I will try to give photo. I think since sandisk mcu is not supported we can solve this case if issue is restricted to electronics level only.
I can at least check basic voltages to conclude if we get schematics. I will update once I get it.
